Question about Zebra LS3478-FZ Handheld Rugged Cordless Bar Code Reader Handheld Barcode Scanner
Connected LS3478FZ symbol scanner via RS-232 but barcode output not coming out to applications
  • Anonymous Mar 20, 2014
    I got a MC9090 with a CRD9000-4000E 4 Slot Cradle ethernet-rs.232 cable. And when i try to connect to my PC it cannot recognice the device
2 Suggested Answers
  • 185 Answers
SOURCE: I'm inputing ASCII via RS232 would like barcode printout
You will need to send the data using ZPL or the printer won't recognize it , if you don't have experience in this area print through the Zebra Print Driver should work. In your application use Barcode 128 as the font and see how it goes
Posted on Oct 29, 2009
Scanner lose settings over night
Check the PC shutdown time it can shut off in period if there is setting for it .
Jul 19, 2016 | Symbol LS 4278 Barcode Scanner
Cab't get computer/application to recognize the scanner
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11585&sliceId=&dialogID=227820981&stateId=1%200%20227814895
This unit is only supported by Windows 2000 or Windows XP environments.
Regards,
Dan
IT Professional
May 04, 2011 | Symbol P470-SR1211100FB Handheld
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
Oct 28, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
Symbol LS 4000-I100 to a PC Help connecting
That depends on your exact model, it could be USB, Keyboard Wedge, or RS-232. In any case, you just plug it in and turn it on.
Oct 15, 2009 | Symbol PN: LS4000-I100 Laser Scanner...
Need configuration and reset barcodes for Symbol LT1820-I100A
Hi, the LT1820 is strictly an RS-232 device. The Product Reference Guide can be found at the link below and the Set Defaults barcode is on Adobe page 47 of 105.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=0804302bpdf&sliceId=&dialogID=14395378&stateId=0%200%2014391883
This scanner's default RS-232 settings are 9600 baud, Even parity, Two stop bits, 7 data bits, and no hardware or software handshaking. Standard RS-232 is normally 9600, 1 stop bit, 8 data bits, no parity, no hardware or software handshaking. I hope this information helps.
Oct 10, 2009 | Motorola Computers & Internet
Symbol LS2208: Suffix with 2 x ENTER
You may need to enter two "rules", each adding an "enter" to the data. This is programmed by scanning special barcodes in the manual, which you can download here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Aug 27, 2009 | Symbol LS2208
PSC Duet RS-232 Handheld - help needed :(
hello The cable has taken power?
it is important to the power adapter and cable PSC.
fai photos to the cable and sends me. Then explain how to connect to xp.
hello Roberto
Jun 04, 2008 | PSC Duet RS-232 Handheld Barcode Scanner
Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Jun 27, 2007 | Symbol LS2208-7AZK0100S Handheld
Imageteam IT3800 scanner won't hold the config.
Does the scanner use a small battery to keep the stored information? If it does, this battery might be defective.
Feb 26, 2007 | HHP ImageTeam 3800LT (3800ltp-12) Handheld
Zebra LS3478-FZ Handheld Rugged Cordless Bar Code Reader Handheld Barcode Scanner Logo
154 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
