Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag refrigerator Model MZ02766GEW does not dispense water
Maytag refrigerator Model MZ02766GEW side by side.  The ice is working fine but the water takes 15 minutes to pour. I've change the filter 2X. The lights are working fine.  The problem started after the water was ******* for a week and the house water meter was changed.
  • malteses7 Dec 02, 2008
    I hold a container and wait 15 min, then I collect several gallons of water to release any sediment or air in the line.  The collection was fine the water flow was perfect.  An hour later I tried to collect water again but the problem is still there.  I have done this several times.
    How I shut off the valve.  You mean I turn off and on the faucet of the water supply?
    How I could change the selenoid and the pump assembly to tried the solution presented before.
  • Anonymous Mar 16, 2014
    Maytag
  • 828 Answers
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
  • James Helmer
    James Helmer Dec 03, 2008
    Shut off the faucet that supplies the water to the refrigerator. Disconnect the line in back of the refrigerator for the water supply. Direct the line into a container and turn the faucet back on. This will give you an indication of the flow. If you have good flow at this point, remove the inlet part of the refrigerator solenoid where the water was connected to. This should expose a screen filter. Clean the screen and reassemble. Reconnect the water line and turn the water back on. Check flow at the dispenser.
Ice maker not making ice
The solenoid that lets water into the ice maker is not working. The ice maker itself can also cause a working solenoid to malfunction.
Jan 15, 2014 | Maytag MSD2434GE Side by Side Refrigerator
I have a maytag side by side frig model # msd2578vemoo the ice machine works but the water dispenser does not work
You will need to replace the water inlet valve on the back of the refrigerator. One line is for the water dispenser and the other is for the ice maker. The side for the ice maker is not energizing the solenoid to let the water thru to the ice maker. Here is the part you need to order.
Nov 10, 2012 | Refrigerators
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still...
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water dispenser.so in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
May 29, 2011 | Maytag Refrigerators
The ice maker quit working but I still get water from the door dispenser. It's a Maytag model MSD2456DEW
I know this is late but I will tell you that most times the water control valve on the rear of refrigerator is the reason for the ice maker not to refill. Yours uses a part number 61005626 dual water control. One side for dispenser and the other side for the ice maker. You may test the ice maker to insure that it works by filling with tap water. Let freeze and if it dumps the then ice maker will try to refill after each cycle. If the water control valve works it will refill. Let me know if you still need assistance. Thank You, Sea Breeze
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
My maytag water dispenser not dispensing water
I am sorry I can not find a model listed Maytag Email me with the correct model or visit my site to see where to look for the model numbers.email is appliancepartsse@yahoo.comsite is below, Thanks, Sea Breezehttp://servicepartstec.blogspot.com/
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
No water coming from dispenser on Maytag MZD2766GE
You should defrost the freezer. The water line coming into the freezer is frozen and the water can't get through the little tubing.
Feb 01, 2009 | Maytag MZD2766GES Side by Side...
Ice maker working fine - Water dispenser nto doing anything
hi there,
sounds like the water valve may be the culprit.
can you provide the model # off your fridge please?
Sep 21, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
412 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
