Question about Sony Cyber-shot DSC-W70 Digital Camera
Camera clock when i remove battery from my camera the date is changed to its initial date, what is the problem? can you give me suggestion?
The small internal watch battery that keeps record of your settings when the camera has no other power source may have died. I recommend sending it to a certified camera repair shop to have the watch battery replaced, unless you're the type of person who is good at taking apart small electronic devices.
Posted on Dec 08, 2008
Having to set the date and time every time I change the battery.
Your clock battery is dead. Simple to replace. Any place that has batteries should have what you need. Just find the number on the old battery. Good Luck
Mar 01, 2016 | Sony A55 Digital Camera
I have the JVC digital minidv camcorder, Model No. GR-D270U an it keeps telling me it's in safety mode and I can't even get the tape out beause the door opens but it's like the mechaism to pop...
After trying the remove-and-reattach-battery exercise, I would suggest you go to the menu and find the setting for initial setup. Select that - which may reset the system.
If not.. then try going to the clock and change the date/time settings, turn the camera off, remove-and-reattach the battery. Re-power the camera, go back and change date/time setting to what's current. And try to eject the tape.
On one of our analog video cameras it seems like there was a tiny little hole someplace on the side of the camera that you could use a tiny small thing like a toothpick to press in there to accomplish a Reset. (It will have tiny raised letters saying "Reset" right beside the little reset hole.)
May 16, 2011 | JVC GR-AXM270 Hi-8 Analog Camcorder
Each time I remove the battery from my Nikon CoolPix 4300, the clock returns to a default of 2002 (in the LCD window the date shows as 000000. Each time I use the camera I have to reset the clock and date....
I probably need more details but, it sound like when you remove the battery to recharge it, the clock loses any power it had. Most people have a second battery. When the first battery begins to lose power, they insert the fully charged battery so the clock is only without power for a few seconds. Try that.
Aug 13, 2010 | Nikon Coolpix 4300 Digital Camera
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
Cybershot will not store clock settings
Hi!
The internal battery is bad. It has to be replaced. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
hi there...i have the same problem..did u find any solution for the very same..
get back to me on
anand_doshi@in.com
Jul 06, 2009 | JVC GC-S1 Digital Camera
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Embedded date on photos
this camera has an internal clock battery, which must keep the date or any other related information while you changing the batteries, the problem is, since you camera is pretty old, the clock battery is probably long dead, it can be changed, but it will require disassembling and resoldering
Aug 19, 2007 | Kodak EasyShare CX4310 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
49 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
