SOURCE: Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
SOURCE: Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
We had this problem - fixed today - its the chimney fan which extracts fumes and sends them to the cooling fan. Its an easy fix when you see the engineer replace the fan. Neff were excellent my warranty ran out 6 weeks ago and they replaced the part for free and all I paid was a call out charge. The rattling was caused by the blades coming loose from the fan
SOURCE: replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
