Panasonic PV-SS2710 - White noise/bad audio in HDR mode
When the TV is in HDR mode the audio is horrible but video is perferct. When switched to BYPASS audio is good. I'm thinking it the HDD inside. There is an 30Gb Seagate IDE HDD inside. Do you think that would fix the problem if I change the HDD inside the unit or do i need to look else where. Also when you record a show or something in BYPASS, when you playback it sounds the same as it would in HDR. Only when you have something that is played from the HDD that the sound is bad. I will try to change HDD when I get one available. I would like to add an larger HDD to increase recording time/space eventually anyway. Please reply.
  • oic800 Apr 21, 2009
    I am having the same problem after moving the set 3 feet. Getting white noise that will only reset when bypass is pressed. I may try setting up a home stereo system to see if it plays clearly.
  • 86 Answers
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Posted on Jan 22, 2008
SOURCE: DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Posted on Feb 10, 2008
SOURCE: CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Posted on Feb 23, 2008
  • 3 Answers
SOURCE: PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Posted on Sep 21, 2008
SOURCE: No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Posted on Oct 11, 2008
Howdo I hook a DVD player up to this model?
The easiest way would be to hook it up using the composite cables from the DVD player to the Rear of the TV.
First safely and slowly turn your TV around you should see inputs in the rear of the TV.
Second identify your composite inputs. They will be visible via the standard RCA Composite colors, which are Red(Audio), White(audio), and Yellow(Video)
Third Once you have found the RCA Composite Inputs, Take the cable which are inserted into the DVD player and Plug it into the TV's Composite Inputs.
Once all that is done, turn on your DVD player. Then using your TV's remote Press the "TV/VCR" / "Source" / "Input" button on your remote till you see video from your dvd player displayed on your TV.
Here is a link to the User Manual:
http://www2.panasonic.com/consumer-electronics/support/TV-Combos/model.PV-C2540
Hope this Helps.
Mar 18, 2011 | Panasonic PV-C2540 25 in. Combo
Picture on my Panasonic PV-DF2700 flickers and then there's a blue screen. Cable company says signal is going to TV. Is the TV history?
Hello, the tuner could be ready to go out entirely, but you can still view your cable TV through your Auxiliary input jacks(video/audio colored jacks) most of the cable boxes ave these outputs in the rear all you need is the RCA cable(yellow/red/white) and select the video input you want to use. The other solution is to replace the tuner. You can order one through www.partstore.com or directly from panasonic at their website www.panasonic.com.
Nov 26, 2010 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
Panasonic pv-gs15
You need 3 cables Yellow, (Video) + Red & White, (Audio L&R Stereo) Or Mini-DIN, for SVHS Video cable, this is ONLY for Video, Audio, is still Red & White. Or Component, where you have 3 Video Sockets, cables, Green, Red, Blue, All video, all color to color, both ends, and again Red & White for Audio. Sometimes there is FireWire, or HDMI you need a cable and the PC MUST also be equipped, You need software and drivers for FireWire, of HDMI..
Mar 26, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
Panasonic dvr replay only shows in black in white
Bad cable connection, change cables, change splitter, go to RCA input.
Apr 15, 2009 | Panasonic PV-HS2000 Showstopper 30-Hours...
Connecting a panasonic dvd player to a 38 inch toshiba tv
Check the TV menu for S video to composite video mode setting if there is any.
Try switching this mode and if nothing then tell me whether u are using component video or composite video cables
Rifaa
Nov 17, 2008 | Panasonic Toshiba MW20F51
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
PV-HS2000 Showstopper freeze up and noise
send to Panasonic Digital Svc Center, 410 B Airport Road, Elgin, IL 60123 - $149.95 + $30 return shipping. You have a bad hard drive and they will take care of it for you.
Dec 24, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Play games on tv
go to channel 1 if there is no audio/video switch or you can use the rf mudulator
Oct 11, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
