Question about Dishwashers
Gd morning We have Bosch Hydro Sensor diswasher which is not getting hot during wash cycle. Only cold water ? Thank You
    Scholar:
  • 82 Answers
Hello tacfire,
There is a in line heater that is underneath the unit which has probably gone out. If I remember right it is connected to the circulating motor. I don't recommend doing it yourself, as it is very difficult to get to and it is hard to get it to stop leaking when you put it back together. If you decide you want to tackle it anyway, let me know and I will give you some tips.
Sincerely,
shays5415
Posted on Dec 03, 2008
  • 40 Answers
I need a specific model number to locate the repair documents. Most likely the heating element has gone out. Do you have a plate warmer feature? If so see if your dishwasher will heat up. Many dishwashers use the same element to heat water and dishes.
Posted on Dec 02, 2008
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
No hot water coming in during the wash cycle.
Hello Stephen Foster - Based on the symptoms you are describing, typically, the unit could possibly have a faulty timer, temperature sensor or water valve. Confirm that the holes are properly connected. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if the issue persists, it is always a good idea to have a service tech properly diagnose your appliance.
Apr 15, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Admiral washing machine water not hot enough during all cycles.
newer washers have a temp sensor and the washer is programed for around a 100 to 110 degrees F, depending on manufacturer, so if your washer is new it is doing what it is supposed to do, sorry.
Jan 03, 2012 | Washing Machines
On the regular cycle for Bosch Nexxt 500 series, during the warm or hot cycle the washer interrupts the cycle with error code "E02" and stops washing . . . how can I fix this? I've made sure the door is...
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
Jul 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water at dish washer is not hot but water @ sink is hot. (right next to DW)
the dishwasher is normally on cold fill only and heats up water during wash cycle they can be connected to hot but is not recommended.
May 08, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My Maytag Atlantis Mod.# MAV7600AWW doesn't come on with the cold water selected. It will come on with warm or hot water. The spin cycle seems to work ok when dialed to it. Before the washer seemed to...
the machine control opens both hot and cold water valves and then the machine sensor monitors this through a water temp sensor in the fill line till a certain amount of resistance is encountered so it could be a faulty sensor,machine control board or also if a certain type of wash is selected it wont use any cold water at all during the whole wash cycle
Mar 13, 2010 | Washing Machines
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I used the cold cycle selection but I noticed that during the rinse cycle hot water was draining into the washtub. I wanted a complete cold water wash. Recognize that detergent can clog drains but I don't...
Check to see if hoses aren't reversed. Do you have an electronic temp-aaure on the unit as this could be bad as well. Also, check to make sure the valve is O'k as you could have a bad inlet valve assembly
Aug 02, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
No hot wash
If you shut off cold water the sensor will send message to computerized box the machine will not operate. it shut down the machine.
Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
