Question about Seagate 500GB Maxtor Diamondmax21 SATA2 Hard Disk Drive 7200rpm 16MB STM3500630AS 500 GB SATA Hard Drive
Problem related Seagate Hard Disk
I have seagate IDE Hard Disk 80 GB. Previously it was working fine but from last day it is not being detected by its own system where i was using it or not with any another system. Whenver i boot my system it is giving error that hard drive is not available.
Can u please suggest me, exactly where is the problem and what i can do form my side. Already i have tried every step with which we can make any hard disk deetect with system. but it is not happening.
I am eagrly waiting for your advise.
I would really appritiate for your advice and guidens..
Regards,
Gaurav Rana
  • 31 Answers
I also encountered that problem about using seagate. first make sure that theres no loose connection between the MotherB and HardDisk. Or maybe it has a virus or a bad sector.,Try this, if you have another hard disk, try to make the 80gb a slave drive. then format it using windows base process (Right click the drive then FORMAT). or try DEFRAGMENTATION and scandisk for that drive.
Posted on Dec 01, 2008
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
My seagate 80 gb ide has got its MBR corrupt, help me out ihave tried almost all things, i want a direct MBR writer. please
the same problem i got few days back. but did;t find any proper sollution. The only thing u can do to format it.
Jan 06, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
COMPAQ PRESARIO V2000 BOOT PROBLEM
As much as I would like to tell people do not buy seagate I can't, Most Seagates are having problems, depending on the serial number you might need the firm ware up date. Secret WD is the way to go, better warranty, last longer to.
Feb 21, 2009 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Total size is not 80 GB IDE Hard Drive
Two possible solutions but both calls for another software/utility.
1. Use FDISK but you should be booting and running in DOS mode;
2. the other is Partition Magic which runs under Windows environment.
The idea is to delete the existing partition (that shows only 31.50Gb) and thereafter re-partition to the full capacity of the drive. of course doing so would erase the contents. Further, a format after the re-partition is required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 19, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Hard Disk Got crrupted
If it is corrupted repair the operating system or reinstall it.
It HDD is not working you may appraoch Segate service in Ernakulam for Replacement of it. They may take 15 to 30 days for the procedure. Your warranty is vaild across India.
May 30, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Seagate 500GB Maxtor Diamondmax21 SATA2 Hard Disk Drive 7200rpm 16MB STM3500630AS 500 GB SATA Hard Drive Logo
153 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
