Question about Intel Motherboard
New motherboard - system shuts down at windows login screen.
All,
I purchased a new motherboard, CPU and RAM at the weekend. Replaced my ASUS MB and AMD x2 3800 with a Gigabyte GA-MA74GM-S2H and AMD x2 6000 with 2 x 2gb DDRII RAM.
Fitted the MB and chip, booted the PC and checked the bios values OK. However, as soon as it loads windows (XP home SP2) to the login screen, the system powers down.........power just cuts.
Things I have tried:
* New power supply
* New hard drive - formatted, started OS install routine, got to the point of loading windows, powered down.
* Removed all peripheral connections so only had Motherboard and HDD connected to power
* returned both MB and CPU to shop and exchanged as I concluded it must be faulty. Fitted replacement MB and chip - same again.....powered down.
* run the motherboard outside of the PC chassis
None of the above had any effect.
I can run the bios prog for an extended period of time. It's only the loading of the O/S which causes it to power down.
Any thoughts? I'm tearing my hair out here.......I feel like I've troubleshooted for everything.
  • 2 more comments
  • david_green Dec 01, 2008
    Hi guys
    I tried all combinations of RAM in/out etc. I'm sure it was seated OK - when the system boots, it sees the ram correctly.
    Would loading the OS alone increase the temp of the chip? When I formatted the new drive, it was running for 2 hours without error.
    When I took the fan out of the box, it did have a thin film of thermal paste underneath it which I assumed would be enough. Is it worth applying a little more to ensure better connectivity between the chip and the heatsink? I know they are connecting as the chip has the paste residue on it.
  • markus
    markus Dec 01, 2008
    sounds strange...i got the same motherboard and a amd 5000+ and 4 gb corsair sticks no prob lems at alll.
    Next i will try the harddrive ....maybe is defect.
    Try with hd tach....
    Which harddrive do you got.?
  • david_green Dec 02, 2008
    An update.
    Bought some thermal paste last night and remounted the HSF. Looked in the bios and the temp was running at 50c. Loaded windows.......it predictably shut down at the login screen. Immediately booted back up, checked the CPU temp in the bios and it was 75c. I'm assuming this is too high a temp and the pc is powering down as a result.
    (As a relative novice) I'm surprised the CPU temp increases in such a short period of time, from being ambient temp to over heating in the time it takes to boot the machine to windows login (30 secs).
    The motherboard, CPU and fan were purchased as a bundle from PC world. Do you think the fan they've bundled in is insufficient? I tried my old fan from my X2 3800 and the same problem persisted. Do X2 6000's require some serious cooling??
  • Anonymous Dec 29, 2008
    I have a similar issue. Also purchased a bundle at PC world.
    In my case system shuts down running a game - general usage is ok.
  • 24 Answers
Fiend your solution direct from Gigabyte. Here is your solution.....
http://www.gigabyte.com/motherboard/prob676ijt65/solution
884
Posted on Mar 02, 2009
  • 31 Answers
It must be the ram thats not fitted in the motherboard. Try to replace the ram then boot the pc again.
Posted on Dec 01, 2008
  • humbletech
    humbletech Dec 01, 2008
    check the settings of the bios, if theres a settings that disregard the temp of the pc then turn it on..Or try to adjust the temp for maximum temp..
    Champion:
  • 253 Answers
Check the cpu temperatur in the bios...maybe the cpu get over the max temp and shut down...
Or re install the cooler if it is to high.
Try one ram stik....
  • markus
    markus Dec 02, 2008
    i bought a cheap northQ cooler for about 35 dollar and this cools my 5000+ on max 35 degrees...
    But a 6000 x2 needs maybe more...
    On my other pc with a intel E6850 3ghz i got a
    Noctua NH-U 12 P and this is a master for cooling but expensive too...
    look around what other use for cooling maybe you got to much termal paste on it....
4 Suggested Answers
  • 883 Answers
SOURCE: PS_ON revertsto high as soon as +12V starts to appear on 2+2connector
usually it is over-current that will make PS_ON go high. However, the opposite is true: if not enough load draw, PS_ON goes high and never goes low. Not exactly certain about link to 12V2+2 connector, although same theory may apply.
Posted on Nov 20, 2007
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
SOURCE: pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Posted on Jan 12, 2009
P5PL2 display shuts off after proper bootup
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5PL2&p=1&s=22
Try to update the graphic driver, from here:
http://support.amd.com/us/gpudownload/windows/legacy/Pages/legacy-radeonaiw-xp.aspx
This is the driver for xp, and please uninstall ALL old drivers before installing the new.
You can select another driver, for the windows system here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
If i`m wrong by the system.
Update the missing system drivers, if any, and run windows update for the latest bugs and fixes.
But the power supply, could also be failing, or not giving enough power, i have seen this before.
Good luck
Feb 15, 2013 | ASUS P5PL2 Motherboard
I have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one long then two short, with...
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
Feb 28, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus A8V-XE motherboard keeps shutting down, just put new power in and it is still doing it
Hi
Kindly see if the CPU fan is working properly. This might be a system shutdown due to overheating components
Hope it helps..
Thanks for reaching Fixya.
Leave comments for further assistance.
Apr 03, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asus mb wl300 amd 64 4000+ won't boot to bios.
To make sure it isn't anything else, pull all cards, and drive cables from the board so the only thing left connected is the power connectors to the motherboard, the speaker, and the power button. Pull all the ram cards.
Now power up the computer. If you hear a series of beeps then the computer recognizes there is no ram on the board. At this point I would take the power supply out and have it tested. If you do not hear a series of beeps I would still have the power supply tested as it could be the 12v is fine but the 5 and 3.3 volt side is bad.
If power supply tests good then I would replace both the motherboard and processor. You take a risk of burning a new processor if it's the motherboard causing the problems.
Jan 08, 2010 | ASUS Computers & Internet
Problem with Shutdown
try microsoft/windows update, its on the start menu
reply if you still need help have a good day please rate bama46
Aug 22, 2009 | ASUS P5QL PRO Motherboard
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
System over heating
Simple reason is Replace your SMPS .
Apr 02, 2009 | ASUS K8N-DL Motherboard
Problem after updating asus bios
The first thing I would try is to clear CMOS. Either set the jumper on the motherboard to do this, or even remove the battery, and wait half an hour or so. When installing a new CPU, and even RAM, you should always clear CMOS.
Cheers
Nov 11, 2008 | Computers & Internet
Intel Motherboard Logo
299 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
