Question about Maytag LAT3600A Top Load Washer
Maytag Atlantis MAV7600 AWW
Makes a loud squeak evertime it stops spinning?
  • 1 more comment
  • klemv Dec 18, 2007
    Loud squeak everytime stops spinning. Sounds like brakes on a school bus!
  • Anonymous Apr 06, 2008
    Hi...I have the same problem everytime my Maytag Atlantis MAV7200 AWW stops spinning it do so with a loud squeak...David
  • Anonymous May 25, 2009
    WHEN THE SPIN CYCLE STOPS THERE IS A BLOOD CURDLING SCREECH. THE PREVIOUS COMMENT THAT IT IS NORMAL IF YOU LIVE IN A DRY CLIMATE IS RIDICULOUS! IT IS OBVIOUSLY A BRAKE PROBLEM THAT YOU SHOULD BE ABLE TO REPAIR.
    Problem Solver:
  • 6 Answers
Normal brake sound in dry locations. Do you live in Arizona?
Posted on Mar 05, 2007
I have a kenmore stacked washer/dryer that squeaks in the spin cycle. What could it be??
i had that problem too. i noticed that is was not flat on the ground. You can also try putting oil on it.
Dec 09, 2012 | Kenmore 98702 Stacked Washer/Dryer
Dryer makes a loud squeaking noise while spinning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 02, 2011 | Whirlpool LEB6200 Electric Dryer
Washer runs very loud while spinning and stops very loud. Squeaks and squeals!
Sounds like the main drum bearings have failed. remove drive belt, and spin drum by hand, if it feels rough or is noisy, then the bearings have failed.
Please rate my solution.
Thanks.
Nov 05, 2009 | Washing Machines
WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Re Your solution for my washer
its the spin brake making noise at the end of spin. once it gets humid out it will start all over again. its very comm. with this unit.
Apr 08, 2008 | Washing Machines
Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Apr 06, 2008 | Maytag Atlantis MAV6451 Top Load Washer
This is a very com. prob. with this unit. its is expensive to fix and will come right back when humid out best thing to do is just put up with it.
Apr 06, 2008 | Washing Machines
Maytag LAT3600A Top Load Washer Logo
328 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
