Question about JVC KD-S580 CD Player
Will not work
When I installed this player into my 1987 ford bronco and powered it up the display said <<>> and then I got nothing.....not even speaker sound. What, if anything,did I do wrong......the fuse is good but it is a 20A and not a 15A would that make a difference?
    Problem Solver:
  • 9 Answers
Possibly, But unlikely in my expierence. try taking the Radio, Twist the Red and Yellow wires on the harness together and ground the balck wire and touch the Combined Red and yellow agains the Positive battery terminal, This should power the unit on and let you know if it is functional. If that works then you can look at the wiring in the bronco to ensure you have the constand power, and the Accessory power working Correctly. I would try to replace the fuse with the correct amp. fuse first though.
Posted on Feb 17, 2007
  • Elijah Bell Feb 17, 2007
    P.s Make sure none of the wires are crossed except for the red and yellow -=Constant Power and the ACC=- or else you might fry a channel in the head unit.
1987 Ford Bronco - Recent Questions, Troubleshooting & Support
Wiggle the engine harness and see if the engine dies, do this everywhere that the harness has allot strain on it due to engine movement.
Jun 09, 2016 | 1987 Ford Bronco
Power window main switch won't work for drivers side window 1987 ford bronco 11
replace switch! if still don't work check the window motor!
Feb 09, 2013 | Cars & Trucks
Trying to install starter solenoid for 1987 Ford Bronco full size 302.5 engine. Cann't figure out color wire placement.
as you can see all wires go with the loop on them go to the side nearest to the firewall, plug one on top and starter wire goes to the one closest to the battery.
May 10, 2010 | 1987 Ford Bronco
Rear window on my 1987 ford bronco will not work
This has several possiblilitys, it could be the switch in the dash has gone out even if it does not work with the key in the tailgate. other possible item could be the window motor or a sensor that detects if the gate is up or down. check motor wires for power when the switch is activated by pulling off the panel on the tailgate, if it is getting power i would suggest replacing the motor. if not you may have to trace wires to the drivers side of the tail gate and find the sensor.i had to by pass mine a while ago. makes it much easier to clean the glass on the inside cause the window will roll up with the gate down.
Where do i find a transmission for a 1987 bronco 2 or ford ranger
I would check car-part.com. It's a website that will show available parts for your car from auto recycler's in your area.
May 08, 2010 | 1987 Ford Bronco II
Windshield whipper fuse were is it for a 1987 ford bronco. Cant find whipper fuse to check it.
Below is the fuse lay out for 87 bronco, no wiper fuse is mentioned. if they do not work i would check to see if the wiper motor is getting power, if so then replace wiper motor
Oct 27, 2009 | 1987 Ford Bronco
I have a 1987 ford bronco and will not start replaced the pick up coil and ignition module and coil and still not getting spark to start now I am stumped can some one please help?
check the wires to the module,im not too sure what color wire to check,its been 5 years since i worked on that issue on a ford truck,but i think its a white wire with a black stripe-basically power from the key-also check the fusible links by the starter solenoid on the inside fender
Aug 10, 2009 | 1987 Ford Bronco
1987 ford bronco fuel issues
First thing to check out will be the fuel pump relay under the hood. It is the one who drives the pump, so if it is defective the pump will not work either to prime the engine, or to make it run. Secondly, you need to check if the fuel filters are OK cause sometimes they clog up and prevent enough fuel from reaching the engine. Thirdly, check the injector(s) for cloging, and clean or replace them as needed. If none of this helps, then the problem probably has nothing to do with fuel delivery, and the next step to check will be the whole ignition system, which is also one of the most comon bronco problems.
Jul 07, 2009 | 1987 Ford Bronco
JVC KD-S580 CD Player Logo
56 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
