Question about 2wire (1000-400108-001) Router
I bought a 2Wire gateway router / modem.
And hooked it up to a PC. Now trying to network 2 wireless laptops to use the printer. Both laptops can access the internet through the gateway easily. It says we need to purchase adapter cards for wireless wi-fi. Is this the only wireless way to print through the network?
  • sathomas074 Mar 04, 2009
    at&t 2wire keeps loosing wireless connection. I don't have the at&t service. Any fixes.
  • charles raynor May 11, 2010
    Are you trying to access a printer that is attached to another computer on your local network? or is the printer set up as a wireless on your net?
    If the printer is connected to another computer, you need to set that computer to share the printer.
    If it is a wireless printer (like a Lexmark4500) do you have the proper software on your laptops?
    Scholar:
  • 44 Answers
Type ur IP address on ur address bar 192.168.1.254
and go to ur firewall and then advanced settings
go to the bottom and allow all application
that should do the trick !
if you cant remember ur system key click forgot password should give you a hint if that dosnt work try still cant remember password
Posted on Apr 10, 2009
  • July Towers Apr 10, 2009
    if its set correctly and still cant printer access the modem 192.168.1.254
    go to firewall | advanced settings | then allow all applications at the bottom should be a check mark
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
May 28, 2009 | Gateway M305CRV Notebook
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless laptop with win.vista can't connect to my 2wire
1st Look for a wireless network, it will be named 2wireXXX (XXX = the last 3 digits of the serial # on the bottom of the 2wire modem.) When it asks for a WEP or a security key, it will be on the bottom of the modem in between 2 bar codes and it will have [ ] around it, this should be a 10 digit #. If that does not work. I had a problem with my MAC and my Windows VISTA 64 BIT Laptop not being able to keep a stable connection with the default wireless username and password.
To get into the 2wire: Open a Internet window Address Bar 192.168.1.254 Home network "At the top of the page" then click on wireless settings "Also at the top of the page" Then you are in the wireless config to change the information.
What i had to do is change the wireless authentication to WPA-PSK and change the wireless password (Use a 10 digit Number as the pass-code, a phone # would be a good suggestion) , what you also need to do is change the name of the network along with the channel of the wireless, it helps if you take it all the way up to 11. Then you should be smooth sailing all the way. :-)
Feb 04, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Wireless connection to the 2 Wire modem
Hi
Most of the 2wire gateways have the WEP key or the encryption code on the bottom of it. It would a 10 digit Number of a Five Character one within square brackets.
Other wise you can go to the gateway page by accessing http://192.168.1.1 on another system which is already going online using the gateway or wired to it and in the gateway page under wireless you would find the WEP key incase the default key on the bottom of the 2wire does not work.
Do reply incase this has resolved your issue or you need more help.
Thank you
Rakesh
Expert in Dell Laptop.
Jan 05, 2009 | 2wire (1000-400108-001) Router
Just bought a 2Wire Gateway, router/modem.
Try contacting your internet provider for set up instructions.its probably a configuration problem.RICHARDM69
Dec 01, 2008 | 2wire (1000-400108-001) Router
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
2wire (1000-400108-001) Router Logo
403 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
