Question about 2wire (1000-400108-001) Router
Just bought a 2Wire Gateway, router/modem.
Connected the PC okay. 2 wireless laptops can connect to the internet through the gateway, but will not network with the printer on the host PC.
Question: Do we have to purchase wireless adapter cards to print?
    Genius:
  • 1,061 Answers
Try contacting your internet provider for set up instructions.its probably a configuration problem.RICHARDM69
Posted on Dec 01, 2008
Wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
May 28, 2009 | Gateway M305CRV Notebook
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless connection to the 2 Wire modem
Hi
Most of the 2wire gateways have the WEP key or the encryption code on the bottom of it. It would a 10 digit Number of a Five Character one within square brackets.
Other wise you can go to the gateway page by accessing http://192.168.1.1 on another system which is already going online using the gateway or wired to it and in the gateway page under wireless you would find the WEP key incase the default key on the bottom of the 2wire does not work.
Do reply incase this has resolved your issue or you need more help.
Thank you
Rakesh
Expert in Dell Laptop.
Jan 05, 2009 | 2wire (1000-400108-001) Router
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Can not use Internet with new Linksys rangeplus wireless router
Okay chances are your 2wire's ip address is conflicting with your router's ip address. Set up your router to use 192.168.2.1. Save the settings then everything should work for you.
Jun 14, 2008 | Computers & Internet
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
Wireless Internet
I am guessing you are connecting that netgear card wirelessly? Does it get an IP address? Have you tried pinging the router from the laptop once the connection has been made? Try this. Go to the start menu, click the run button and in there type cmd and press enter. Once the black command prompt is open try ping yahoo.com See if that comes up with anything. Also try typing ipconfig and press enter. It will show 3 things.
IP address
subnet
gateway.
The gateway should be your 2wire modem.
Try ping gateway ip and see if that works.
Let me know! thank you.
Jan 27, 2008 | 2wire (1000-400108-001) Router
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
2wire (1000-400108-001) Router Logo
122 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
