Question about Dell Inspiron B130 Notebook
Remove BIOS sytem password
I was working on a friends Dell Inspiron B130 and accidentally added a system and administrator password through the BIOS setup. The first time i put the password in, it worked, but after a reboot, it wouldn't recognize it anymore and i can't figure out how to take it off.
  • 6 more comments
  • sephir08 Dec 01, 2008
    I've tried those solutions already, and it still came to the system password grey screen. Also, note that none of the setup cds are available, but i'm willing to disassemble the laptop since we've done it once to look for the password remove chip, which i couldn't find.
    So far none of those have worked yet. This is a laptop, so i don't think it has jumpers or that reset switch.
    I've just taken it apart and there are no jumpers on it.
    Oh, and the CMOS battery is plugged in by a cord, not directly into a socket. I've removed the battery numerous times, some of those times being longer than an hour, and i am still stuck with this issue.
    Still no luck. Some additional information, when it boots, it's Bios Revision A04. If needed, the system number is #6DL5K91-595b.
  • Anonymous Jan 01, 2009
    my laptop is Fujitso amilo pro v2055
    i re partitioned my laptop's HDD with WinXp Installation CD.
    i partitione C drive too.
    then when i want instal WinXp, when copying driver file computer lock.
    can i restore laptop's drivers?
  • Anonymous Feb 09, 2009
    which is the E-prom chip ? location on dell inspiron 3800 laptop?
  • oongie2007 Mar 26, 2009
    when I turn on my laptop it shoes the dell screen, but then turns into a white screen requesting a password. The problem is when i put the password in it says incorrect. Can anyone help me please!!!
    Sniper:
  • 64 Answers
Remove BIOS password with tutorial help: http://lnkd.in/WN_HMz
Posted on Dec 05, 2013
If your laptop is newer than 2007, most manufacturers have started using Flash chips to hold the passwords, If you remove the battery, you will reset the bios to default settings but the Security Chip will still contain the passwords and will require manufacturer support. Most manufacturers will NOT help you if you are not the original purchaser or you can not produce the original sales invoice. Instead they will invite you to purchase a new laptop.
Posted on May 16, 2009
    Novelist:
  • 84 Answers
Have you forgotten your Laptop's BIOS Password?
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Apr 15, 2009
Hi there
My mate had the same problem with his dell laptop i to tried all sorts of software which didnt fix the problem the only solution was to take the laptop apart and locate the eeprom chip once i found the chip i used the end of a clip on one side of the chip and using the other end of the clip touching the other side of the chip make sure you touch them together with the laptop on what that does is reset the bios once the bios is reset by default there will be no password
Posted on Jan 02, 2009
  • 340 Answers
BIOS password crack, download from here:
http://packetstormsecurity.nl/Crackers/bios/
For Award BIOS’ try these backdoor passwords:
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
For AMI BIOS’ try these backdoor passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
For PHOENIX BIOS’ try this backdoor password:
phoenix
Good Luck
/Teis
Posted on Dec 01, 2008
  • Dell Master
  • 4,806 Answers
You have to try and clear the cmos
  • Lee Hodgson
    Lee Hodgson Dec 01, 2008
    who is the bios manufacturer? for example: Phoenix, AMI etc
    regards
  • Lee Hodgson
    can you boot into the operating system?
    if so download this and flash the bios from within windows:
    http://drivers.softpedia.com/get/BIOS/Ot...
    regards
  • Dell Master
  • 19,396 Answers
If you have taken apart the laptop, locate the CMOS battery and unplug it for 5 seconds, this will erase the bios password.
Let me know the exact model of your computer if you want to know CMOS battery shape and location, the battery looks like a coin, or like plastic covered coin batteries.
  • Ginko
    Ginko Dec 01, 2008
    Here is how the CMOS battery looks like:
  • Ginko
    Ginko Dec 01, 2008
    If you have removed the CMOS battery then you get NO BIOS PASSWORD.
    Evidently you are talking about a different password here.
    Bios password is the one that you get only if you try to access the BIOS settings, describe the password that you get here.
    You may be confusing the bios password with windows user password.
    Tell us when you get the password (accessing bios by pressing the apposite function key, after loading windows etc.)
    Thanks
  • 1,879 Answers
CMOS BATTERY - a flat n round battery that all computers have. remove it and all information, including passwords will be gone
  • 10,515 Answers
The general categories of solutions to reset a BIOS password are:
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
Using a Backdoor BIOS Password Some BIOS manufacturers implement a backdoor password. The backdoor password is a BIOS password that works, no matter what the user sets the BIOS password to. These passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.
AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
  • taran_2005
    taran_2005 Dec 01, 2008
    Every system must store the BIOS password information somewhere. If you are able to access the machine after it has been booted successfully, you may be able to view the BIOS password. You must know the memory address where the BIOS password is stored, and the format in which the BIOS password is stored. Or, you must have a program that knows these things.
    You can write your own program to read the BIOS password from the CMOS memory on a PC by writing the address of the byte of CMOS memory that you wish to read in port 0x370, and then reading the contents of port 0x371.
    !BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
    CmosPwd will recover the BIOS password for the following BIOS versions:
    • ACER/IBM BIOS
    • AMI BIOS
    • AMI WinBIOS 2.5
    • Award 4.5x/4.6x/6.0
    • Compaq (1992)
    • Compaq (New version)
    • IBM (PS/2, Activa, Thinkpad)
    • Packard Bell
    • Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
    • Phoenix 4 release 6 (User)
    • Gateway Solo - Phoenix 4.0 release 6
    • Toshiba
    • Zenith AMI
    If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
    On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
    If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
    Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
    RTC's which require external batteries include:
    Most RTC chips with integrated batteries can be reset to clear the BIOS password by shorting two pins together for a few seconds.
    You will see more than one option for some chips due to testing by various people in the field. Remember to remove power from the system before shorting these pins.
    RTC Chip
    Pins
    Dallas DS1287A
    TI benchmarq bp3287AMT
    3 (N.C.) and 21 (NC/RCL)
    Chips & Technologies P82C206
    12 (GND) and 32 (5V)
    -or-
    74 (GND) and 75 (5V)
    OPTi F82C206
    3 and 26
    Dallas Semiconductor DS12887A
    3 (N.C.) and 21 (RCLR)
    You should be able to discover how to reset the BIOS password stored in most RTC (Real Time Clock) chips by reading the manufacturers data sheet for that RTC. Some RTC's, like the Dallas DS1287 and TI benchmarq bq3287mt cannot be cleared. The solution to resetting the BIOS password on systems with those RTC's is to purchase a replacement RTC chip. How inconvenient!
    Sergeant:
  • 306 Answers
All you have to do is to take the CMOS battery out and leave the computer for 20 seconds and then put it back on
Some computers have a CMSO Battery but require a Flash out in the Flash memory using a Jumper setting.
Theres a jumber the is labelled CMOS Bat in the mother board.
  • 1 more comment
  • AbdulRahiman S Dec 01, 2008
    u wil hav  to remove the battery on your motherboard but if you arent sure of how to doi it then its better that you call in an it professional to do it..
    afterwards after having removed the battery for at least one minute put it back again and then reconfigure your bios
    I think u just take out the battery on the motherboard and place it again,it might work.Your BIOS settings also may lost...
    in some cases You can't erase your BIOS but you should be able to reset it to defaults. Most motherboards have a jumper on the board that you can short to reset the settings. First step, find your motherboard manual or if this is a store bought notebook go to the manufacturer's website and look up your system and find the notebook manual.
  • 162 Answers
All computers desktop or laptop BIOS's depend on 1 battery (a round & flat one)
got to remove it for at least 30 secs
  • uten
    uten Dec 01, 2008
    dell has a trick to reset the bios, seems that it is incorporated so that NO ONE can rest the BIOS by removing the battery. has to call DELL tech support, just have patience is you can't understand the rep.
    Scholar:
  • 135 Answers
There is a jumper inside you mother board you will check your manual in which it is locating. remove the jumper and start your system.
The password will remove.
Hope this will help you.
  • 2 more comments
  • Naveed khan
    Naveed khan Dec 01, 2008
    Please have a look to this link
    http://www.dewassoc.com/support/bios/bio...
    In this article you can see a sample main board in which a red arrow is indicating for jumper.
    Follow this article instruction if you still not found jumper then remove the Cmos battery shown in image.
    I hop this will help you.
  • Naveed khan
    • Dell Technical Support at (800) 624-9896
    • Dell Automated Support at (800) 247-9362
    • If you purchased your computer through a Faculty, Student, and
      Staff (FSS) program or an Employee Purchase Program (EPP), call (800)
      456-3355.
  • Naveed khan
    http://support.dell.com/support/edocs/sy...
    If have not manual then it will help you
  • Naveed khan
    Phone support to Dell
      456-3355.
  • 849 Answers
BIOS RESET SWITCH IS BESIDE THE BATTERY, IF IT IS NOT DONE WITH BATTERY REMOVAL. TURN THE SWITCH ON THEN PLACE IT AT THE PREVIOUS POSITION. IT WILL RESET ALL BIOS AT ORIGINAL FACTORY SETTING.
  • Muhammad Saeed
    Muhammad Saeed Dec 01, 2008
    you need to reset it from the bios switch, situated near to battery on motherboard.
    Genius:
  • 3,422 Answers
HI,
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Remove BIOS sytem password - remove-battery.thumbnail.jpgAnyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 - 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
  • 1 more comment
  • Priya darshan Dec 01, 2008
    !BIOS is a freeware utility which is designed to be a whole BIOS and security suite. It has the ability to decrypt the passwords used in some of the most common BIOS makes such as Award, Phoenix, American Megatrends, IMB etc..
    It also has the ability to brute force the password (known as “blasters”). However, this method is dangerous and can result in some unexpected and unwanted results.
    Note: Because of this applications password cracking abilities, some antivirus software may report it as a virus/trojan. This is a false positive.
    To start using !BIOS, reboot your computer and take note of the BIOS type and version you are running. For example, If your motherboard uses Award BIOS you should look for the text “Award Medallion BIOS 6.0′ or something similar.
    Download !BIOS from here and save it to your desktop. Then, open a DOS command windows by going to Start > Run and type: cmd
    Once you see a black screen in front of you, type: cd desktop
    You should now see something like: C:\Documents and Settings\YourUserName\Desktop>
    Now type the name of the file you just downloaded, if you haven’t changed the name just type in: bios320.exe
    Use the down arrow and choose “Crackers” and then press the right arrow. Using the up and down arrows, select the BIOS that the motherboard is using and press Enter.
    You should now see a menu asking what you want to crack, in most cases its the Supervisor or System Passwords you want to crack, so press the 1 key on your keyboard. It will then show you another menu asking how you want it to be cracked. Option 1 is pretty good so try that first by pressing the 1 key on your keyboard. You should now have your BIOS password.
    Reboot the computer, enter the BIOS and try it out.
    For more solutions please on the below link:
    http://www.ehow.com/how_4519181_reset-bi...
    Goodluck.
    Please don't forget to accept the solution.
    The pictures can be seen by cliking on the above link.
  • 796 Answers
Try removing the bios battery out for 15 seconds and then replace them again and try booting the system...
is that also doesnt work try admin or 12345 as password..
thankyou
    Genius:
  • 1,605 Answers
Power down the laptop. take a pen and paper and write down what you rementber as the password that you put in.
remember; the password is case senstive.
This a safe way to do it. since Dell have put in non-volatile chip for the BIOS password. you have to disasseble the laptop and in order to reset the password.
so, try to remember and see if the password that you wrote down makesense. and try again
    Novelist:
  • 157 Answers
Two options:
1.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
If you were not the original owner of the Inspiron, Dell will transfer registration of the used Inspiron from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
To transfer the registration of a used Dell Inspiron, fill out the Transfer of Ownership form on Dell's web site.
2. If you are NOT the owner (hypothetically speaking, of course) you have the option to reset the BIOS password by physically manipulating the motherboard and jumper pins. This is pretty tricky unless you know your way around the inside of your lappy pretty well. Here are instructions on resetting via jumper pins.
  • 1 more comment
  • Juli H.
    Juli H. Dec 01, 2008
    Im unfamiliar with a password remove chip. If you open the laptop you should see a battery, a small circular one like you would find in a watch or the sort, in the motherboard. simply take it out, wait 30 seconds, and replace it. this should restore it to faculty settings.
    just a note: i know this seems silly, but be sure there is no power to the laptop (either the laptops main battery or a/c cable) when doing this. not only would you probably get a nice shock but the point is to deprive the motherboard of all power and forcing a reset.
  • Juli H.
    the three sentence answer for the win.
  • Juli H.
    Juli H. Dec 03, 2008
    Wow. Seems like all of our responses were perfectly applicable (whether or not you have the ability to apply them) yet you flagged us as inappropriate. Personally, I thought the whole 'Inappropriate' rating was strictly reserved for when someone responded by questioning your ability to read, your mothers chastity, or daring to suggest that inbreeding, like in the royal family, can lead to large ears and lack of competence to use computers in the first place. Not that I would do such a thing, just saying...
    Have fun.
2 Suggested Answers
  • 338 Answers
SOURCE: I was working on a
i would suggest going back into the bios and removing it wit the password you chose.
Posted on Dec 02, 2008
System and administrator password for dell inspiron laptop 1200 model PP10S
  • DELL INSPIRON 1200 Master Password, Unlock Dell Laptop www.novatecdirect.com/.../1200-dell-inspiron-1200-master-password.html ... Mar 31 2015, Dell inspiron 1200 Master Password, 1200, dell, ... and System Disabled Security on Dell Laptop: ... dell inspiron 1200 laptop, reset dell ...
  • Dell PP10S ' eBay z www.ebay.com/bhp/dell-pp10s DELL Inspiron 2200 PP10S Laptop Computer 1 ... The Administrator Password needs to be reset. ... Part Numbers:8 CELL Battery for Dell Inspiron 1000 1200 ...
  • Inspiron Laptop - factory reset no admin password - Dell en.community.dell.com > ... > Laptop > General Hardware my problem is with dell inspiron 1200. Just bought this system. During POST it prompts for an administrative password which I dont have. Displays massage like "this ...
  • Administrator Password for Dell Inspiron 1200 Bios & Hard ... dellpasswords.com/administrator-password/index-of-remove-dell... Remove Dell Inspiron System Disabled Password: Now we have a picture on the right that shows a dell inspiron 1200 laptop with the system disabled password
  • May 08, 2016 | Dell Inspiron Computers & Internet
    Reset admin password dell inspiron b120
    Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
    Go to: http://dell-inspiron-b120-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
    Apr 08, 2012 | Dell Inspiron B120 Notebook
    My son lost the Bios password for a dell inspiron b130 laptop, I took it to a computer fix_it store and they told me there is nothing they can do.
    There might be a jumper setting on the system brd that will reset the password. I can't find the specs on the jumper settings of that model's system brd. There are sites that will bypass the password for a fee. Google " Reset Bios password for a dell inspiron b130 laptop,
    Sep 06, 2011 | Dell Inspiron B130 Notebook
    Forgot password to dell inspiron 1440
    Go to: http://dell-inspiron-1440-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
    Mar 02, 2010 | Dell Inspiron 1525 Notebook
    I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
    Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
    May 28, 2009 | Dell Inspiron B130 Notebook
    Dell Inspiron B130 Notebook Logo
    4,429 people viewed this question
    Alun Cox
