Question about Hotpoint VBSR3100D Top Load Washer
Hotpoint topload washing machine won't water won't stop running.
My washing machine's water won't stop running when in heavy soil load, will stop on its own in normal and light, but starts again and won't stop when in spin cycle. Also, can't figure out how to pop the top to try to find out what the problem is. Don't know what model it is, only that the control panel is all black except the knobs.
  • darkdruid420 Dec 05, 2008
    Ok....I found out a few things about the washer...It's a Hotpoint VBXR1060T4WB 6 cycle topload washing machine. The washer cycles like normal until it gets to the second rinse cycle. The water won't stop running and eventually overflows(Had an inch of water on the floor of my house) Other than the water, it cycles normally. I don't know if the switch is bad or stuck or whatever, or if the tube is clogged. I don't know how to check to see if the tube is clogged...I also figured out how to pop it open. Do I need to trace the hose all the way to wherever the other end is and see if there's anything stuck in it? Also, there seems to be a sucking sound coming from the hose.Could just be the water lines though since they run right under it.
  • darkdruid420 Jan 23, 2009
    are you asking or stating a problem you have? If you're asking, then no it doesn't...Its only the cold water though...the hot water stops like normal.
Washer top load will not stop filling even when turned off
Posted on Jan 19, 2009
Hotpoint WT 960G Smell from the machine when in use.
Usually the smell is caused by bacteria from the soiled water when washing is done on a cool wash. I have told customers before that to clear the smell you need to do several hot washes maybe using your white so as not to fade or run colours and in time the bacteria will clear and smell will also.
Feb 03, 2016 | Hotpoint Ultima WT960P Washer Front...
I get an NF error code and the washer sounds like it's filling, but never does, and then there is water in the detergent dispenser.
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. Try running the diagnostic test by:
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 22, 2010 | Samsung WF328AA Front Load Washer
LED is flashing nF. What does this indicate? Washer is a front load Maytag Neptune, mod# MAH 8700 AWW.
Hi
Try running the diagnostic test by—
Thanks
Rylee
Aug 25, 2010 | Maytag Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
Sep 16, 2009 | Washing Machines
Clothes still come out dirty and soiled
you do not mention the water it must be enough pressure inlet water.
thanks
Jul 04, 2009 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Hotpoint VBSR3100D Top Load Washer Logo
727 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
