Question about Maxtor One-touch III Mini 40 GB USB 2.0 Hard Drive
Maxtor 80gb hard disk not dtecting
When i connect the maxtor portable 80 gb hard disk to the computer it detects the computer and within seconds it gives a message that the device will not work properlyin the device manager properties menu it shows that the device cannot start error (code 11)
  • 728 Answers
You might want to try downloading this fix from Microsoft. http://support.microsoft.com/KB/908673, as your first line of attack.  The problem seems to be within your usb 2.0 hub on your computer.  See if this helps.
Thanks for posting.
Mark
Posted on Dec 02, 2008
Hi, I have a segate barracuda 7200.9 160 gb hard disk which was working fine with my desktop but when i am connecting it to laptop thorugh USB it is showing in device manager as portable media.. showing in...
I would suspect that Windows is screwing things up, your laptop cdrom drive should be "d" drive and your portable usb drive should be the "e" drive. You could try to change the usb to "e" in disk management, failing that I would reboot the laptop with usb drive connected to see if Windows straighten things out.
May 14, 2017 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
How can i recover bad sectors in my hdd drive using a startup disk?
Boot from the startup disk.
Run 'CHKDSK' with the '/F' (to "fix") option.
Oct 18, 2010 | Seagate 80GB Maxtor DiamondMax Plus20 Hard...
I have a Maxtor Personal Storage 3100 80 GB Hard Drive which has always worked and listed as drive G. However, on eday it just stopped listing drive G. Everytime I connect it to my port hub or to the...
Try a different "data" cable between your computer and the external disk-drive.
If there is an external power-supply, borrow a "multimeter", and test that the power-supply is supplying power (correct voltage and correct amperage).
Try connecting it to another computer.
Disassemble it, and disconnect the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk is working.
If it still is under warranty, either your local retail store, or Maxtor/Seagate will honour the warranty, and replace it.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 internal hard drive not working think it might be the PCB Board not working.
It's possible that you're correct.
However, finding a Maxtor drive with an identical PCB is not going to be easy. Once you do, you can disconnect the "spinning" part of the disk-drive away from the PCB, and then swap PCB, and see if you can then QUICKLY(!) copy all 80GB to a "new" disk-drive.
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor 80 gb portable hard drive copying problem
Unless the data on the maxtor is very important You should format the drive, assuming you are using windows, go to my computer, right click on the drive, it should show the option to format. If the info is very important, my advice take it to a info recovery business.
Lee
Nov 16, 2009 | Maxtor Hard Drive
Help! slave hard drive partition did not detect..
did you change the jumper? make it sure that you change exactly the jumpers of each Hdd...
otherwise,not working or detecting....
Sep 09, 2009 | Televison & Video
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Partision prblem
This is because an 80GB hard drive only has 75GB inside it will not be exact because of the way hard drive manufacturers compute the size. 80GB by name but only 75GB in real hard drive space. much like a if you have a flash drive or a portable uSB you will notice this also.
Dec 27, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
I have a Western digital model wd2500b007-rnn
and I cannot get either my PC or my laptop to recognize the drive. I isolated the drive to another computer with the same error. It says USB device not reognized. I also tried a different port. I have not tried different cables. Can I retrieve the old data on the drive?
Did you find a resolution for this? I am having the same problem. None of my PCs can recognize the drive. Formatting seems to be the only choice but I need to recover my old data first.
Jun 06, 2008 | Computers & Internet
Maxtor One-touch  III Mini 40 GB USB 2.0 Hard Drive Logo
161 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
