Question about Toshiba Satellite 2775XDVD Notebook
Hard drive and memory
I recently bought a 2775Xdvd it came with a 12gig hard drive, and 194mb of ram. The question is can i put a 20 to 60 hard drive in it?
Also i have a another 128 am I able to remove the the 64 and put it in its place? Too have a total of 256megs. Or change them both for 512? And the final Question is where do i find the access panel to change the ram? Thank you in advance Joe F
  • 395 Answers
The laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Posted on Dec 01, 2008
I am having an issue with my Western Digital Caviar Green 1.5 TB 64MB Cache hard drive. Recently, I put my computer into stand by, and when I turned the computer back on the hard drive seemed to have
Check RAM
How many ram modules are in the computer either remove them or swap them always place the larger ram module closest the CPU central processing unit
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry. They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
Hope this helps
Oct 30, 2012 | Western Digital WD Caviar Green WD15EARS -...
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
I have a Toshiba satellite 2775xDVD laptop with 64mb. of ram soldered to a mainboard. It is based on Intel 443ZXM chipset. The official Toshiba manual says that I can acquire a maximum of 192mb of ram on...
A good website to check out would be http://www.crucial.com.
On the main page you can select the maker and model of you computer and it will give you all the options for your laptop. You can even purchase the memory direct from them at a decent price.
If the manufacturer states that you can only have 192MB of RAM then that may be all that the BIOS can recognize.
Mar 07, 2011 | Toshiba Satellite 2775XDVD Notebook
Is ram and memory the same?
Yes it is Ram stands for random access memory .........cheers
Jan 27, 2011 | Toshiba Satellite L25-S119 Notebook
Have a gateway mt3423 when i power on no display i have already bought new memory 1 gig ddr pny removed battery held power button put memory in top and bottom slots still nothing but power light steady on...
You could have memory problem, incompatible RAM or faulty RAM.
Are the RAM the same make and model?
Try inserting one RAM module one at a time to determine the faulty RAM.
When one RAM module works, then insert the 2nd RAM module to see if it works, Swap RAM around in the RAM slots.
Dec 10, 2010 | Dell Inspiron 1525 Notebook
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Monitor not responding to computer
better check the continuity of you cables/connectors.
May 28, 2009 | E-Machines eMachines Desktop PC
Longer Boot time after upgrading the Hard drive
first let's determine if the upgrade cause the boot speed.
Disconnect your NEW HDD and/or memory, one by one and see if you get back your fast boot. Then try with your NEW components only !
If you find it works better with new components only, then first connect your OLD HDD only and try.
If you connect both HDDs on one cable, check Jumper settings for both HDDs (Master/Slave).
Also HDD capacity and type is automatically detected by the BIOS and there is no need to put/change those settings manually.
I believe you new RAM is DDR type, too!
As written in the manual for the board, your motherboard has two pairs of memory slots, and you can use one or two modules of DDR memory, OR one or two modules of SDRAM memory, but you can NOT put BOTH DDR and SDRAM memory modules.
regards.
Apr 22, 2009 | Computers & Internet
Motherboard doesn't accept WD 40 gig on.
When you say "the system didn't work with that", do you mean it didn't identify the drive? When you go into the BIOS setup, are the drives displayed, or are they shown as "Auto"? Did you correctly change the WD drives jumper to Master, and the old drive, to Slave?
May 25, 2008 | MSI Slot 1 MS-6119 Motherboard
Toshiba Satellite 2775XDVD Notebook Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
