Question about Neff V4380X0 Front Load Washer / Dryer
Spins up, then stops.
My machine starts up, but seems to try to pin up to full revs from standing. The drive belt squeeks initially as the motor starts to spin, but almost instantly the motor cuts out again and drum comes to a stop. Thats my lots, nothing more happens...any ideas???
    Scholar:
  • 146 Answers
Sounds like the problem could be in the tachometer. This is located on the shaft of the motor at the back and has wires going from it to the main wiring plug for the motor. The tachometer cannot be repaired and will have to be replaced.
Posted on Nov 04, 2007
Hotpoint BWD129 Spinning Difficulties
IF it sits and you can turn it later, the only thing that would cause that is something heating up and becoming seized. When it cools off it frees itself. I would check the bearings on the drum.
Mar 12, 2014 | Washing Machines
Front loading LG washer WM0532HW squeeking noise as drum cannot seem to spin with clothes full of water
the belt that spins the drum could be worn out or loose. you can adjust it by moving the tenstioner by moving it an tietening it. you may have to use an apropriate spanner
Aug 15, 2010 | LG Washing Machines
Dryer starts, drum turns a few times then stops. On its own, repeats the attempt to start but has the same issue. For a while it would actually start and complete drying cycle after 3-5 attempts. Now it...
if you can still here the motor running it could be the belt slipping,, try running the dryer with a very light load in it ,,if it works ok,,its the belt slipping and it cant turn a full load anymore,,change the drive belt!
if no motor sounds its the programer,,,pricy part!!!
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Motor building revs when clutch is pushed in/ vibration in floor
Hi this is caused by you timing belt being to tight or off a tooth. The tech is trying to get out of pulling it back apart. Go back there and be stern with them it is there fault. Reseting your computers will do nothing on you car due to it not having computer with adaptive learning system. Tell him that and see what he says. I cant stand techs that lie.
Mar 25, 2009 | 2004 Hyundai Santa Fe
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Neff V4380X0 Front Load Washer / Dryer Logo
130 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
