No sound on the computer. was informed that it was erased.
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    name and model of the computer please..if u have the installation CD that came with it then install the audio driver..
  • 849 Answers
Re-install drivers of sound card.
Posted on Dec 01, 2008
  • Muhammad Saeed
    Muhammad Saeed Dec 01, 2008
    did u rate this inappropriate, if not, please report this. it will spoil my rating.
No sound on dell E310 with windows xp
First, check the sound icon on the bottom right corner of the screen and find the sound icon. Double-click it. Is the computer muted? If not...
Did you format your Dell computer recently? If so, do you have the manufacturer's discs that came with the computer? If you did format it, all information on your computer (including the drivers that enable sound) will be erased and you'd have to find/install the driver's again.
Oct 09, 2010 | Logitech X-540 Computer Speakers
Eraseing a sandisk 2 gb flash drive
To Erase everything on the drive you can format it. To do this, plug it in, then go to 'my computer' Right click on the drive, and select 'format'. BE AWARE, THIS WILL COMPLETELY ERASE EVERYTHING ON THE DISK! So make sure that there is nothing that you want to keep on there.
Jul 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I believe I erased my sound driver for emachine desktop. Erasing junk and may have erased the driver as well. We can hear computer sounds but no volume for youtube, etc.
you can't erase the driver when it's already installed, anyway try installing realtek driver:
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#AC
or you can do System Restore in Control Panel, go to Performance and Maintenance(category view) on the left select System Restore, restore computer to earlier time before you erased files.
Oct 31, 2009 | E-Machines etower 400i PC Desktop
Erase information from computer
If You are familiar with the windows installation, you can reinstall windows. During installation, the system asks You about partition where You want to install windows. So: 1. Select option Delete partition, and answer the question of the system "yes". This option erase All your existing information. 2. Create the partition on the same disc. 3. Install the windows on the same partition. That's all.
If You have another partitions or disc, just format it. And don't forget backup Your personal data!
In any case, is much better to sell the computer with the operation system recently installed - it works much better than a PC with used OS. Best regards.
Sep 13, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Cant find sound folder on mini sd card to add tones from computer
This menu displays music files saved in your phone and microSD card. 1. From idle mode, press and hold the OK Key [OK] to unlock the keypad, press the Left Soft Key [Menu], the Directional Key to select “Media Gallery”, then slide out the QWERTY keyboard and press 1. My Sounds. 2. Scroll through the downloaded or saved sounds to select the sound and press the OK Key [PLAY] to listen to the highlighted sound. To erase the selected sound, press the Left Soft Key [Erase], then press the Right Soft Key [Yes]. 3. Press the Right Soft Key [Options] to choose from the following: • Send by Picture Message: To send a MMS message. • Send Online Album: To upload selected sound to sound online server. • Send by Bluetooth: To send selected sound to another Bluetooth device. • Set As: Assigns the selected sound for specific tasks (Ringtone, Contact ID, Alert Tone). • Rename: Rename the selected sound. • Lock/Unlock: Select to lock or unlock the selected sound. • Move: To move the sound to another location. • Erase All: To erase all the sound files in your phone. • File Info: Displays information about the selected sound. Since you can’t Send or Move a DRM file, the Send/Move options will not appear when working with these type of files. With microSD card inserted, you can browse all folders and sound files saved in the microSD card by searching the Back folder . indicates that current file is stored in the external memory. indicates that current file is stored in the phone memory. indicates that you have sub directory for the current folder.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 02, 2009 | UTStarcom Blitz Cell Phone
Grapics, songs ,videos and voicemails deleted whats up?
The following is from the Razr V3 manual: Master Clear - Clear all user settings and entries except SIM card information, erase all downloaded pictures and sound files, reset all options except unlock code, security code, and lifetime timer. Caution: Master clear erases all user-entered information (including phonebook and datebook entries) and user-downloaded content (including photos and sounds) stored in your phone's memory. After you erase the information you cannot recover it.
Hope this answers your question.
Apr 11, 2009 | Motorola Mobility RAZR V3
Reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
entries) and content you have downloaded
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Jan 16, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How can i restore factory setting in motorola v3i without sim card
Master Reset
Reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Reset
Master Clear
Caution:
Master clear erases all information you have entered (including phonebook and datebook entries) and content you have downloaded (including photos and sounds) stored in your phone’s memory. After you erase the information, you can’t recover it. Clear all settings and entries you made except SIM card information, erase downloaded pictures and sound files, and
reset all options except unlock code, security code, and lifetime timer:
Go into Settings > Initial Setup > Master Clear
Jan 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I can not erase the information on my D-drive.
You can actually Format your D drive to erase all the information in it.
You can customize back-up or restore to default in yuor external hard drive when you set it on System Restore/Bac-up in Windows.
Jan 05, 2009 | Compaq Presario Notebook
I need instructions on how to use purchased external storage unit purchased, no instructions included
Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
  • Write down or print out all notes and internet pages because once the format process begins, you will no longer have access to them (or anything else in the PC)
  • As already stated, BACKUP all important files and data! When you reformat your computer everything will be erased!
  • Make sure you have all the CDs and other software. All programs will have to be reinstalled after you format the hard drive. Don't forget about software that came with hardware such as printers, scanners, etc.
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers. You might want to read from this site http://support.microsoft.com/kb/313348
Jan 08, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
