1992 Dodge Caravan Logo
Graham Bachmann Posted on Oct 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas, fuel, and temp gauge doesn't work
Just filled up my tank.. drove home and it was fine.. then i started it again to go somewhere and the fuel gauge, speedometer and temperature gauge didn't move.. so i started driving and my speed stayed on zero and the fuel gauge stayed on empty as well.. the inside dash light doesn't work either. check gauges light came on.. help please
kelly
Level 3:
Master:
  • Dodge Master 616 Answers
  • Posted on Oct 04, 2017
kelly
Dodge Master
Level 3:
Master:
Answers
616
Questions
Helped
180301
Points
1917
Shake ignition switch helps to know what type of car
artie g
Level 3:
  • Dodge Master 873 Answers
artie g
Dodge Master
Level 3:
Answers
873
Questions
0
Helped
245655
Points
2752
You have blown a fuse..check fuse box. There may be one fuse box one in the cabin but also check for the fusebox in the engine compartment.
5 Related Answers
Anonymous
  • 136 Answers
  • Posted on Jun 01, 2009
SOURCE: dashboard gauges dont work, 1998 dodge caravan
These vehicles seem to have a problematic short, my grandfather has the same vehicle with the same problem, i found the short under the carpet on the driver side of the vehicle, under the gas pedal, sometimes wires can crack and break.
MIKE
Anonymous
  • Posted on Sep 27, 2008
SOURCE: 98 dodge caravan problems
I had the same issue with my dodge caravan and after several attempts by the dealer to fix it, it turned out to be a broken wire. They replaced the relay and it would work for a while and then go blank again. Have the wires checked thoroughly.
Anonymous
  • 6784 Answers
  • Posted on Jun 19, 2009
SOURCE: When I fill my gas tank on my 2000 Dodge intrepid,
HI, the fuel gauge sending unit is malfunctioning. this is located inside the fuel tank and, it is part of the fuel pump assembly. replacing this failing component will fix this issue.
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on Aug 27, 2009
SOURCE: 97 Dodge Neon, Dash guages not working? The
I know your fuses look good but try replacing the fuse with a new one.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Nov 12, 2009
SOURCE: 2001 Dodge Ram 2500 - gauges don't work
check the engine to body ground strap. located rear top of engine screwed to firewall Remove,clean, and resecure.
I have a 1991 GMC jimmy. Run fine until I pulled
sounds like the fuel pump is bad. check the fuel pressure with a gage is should be 35lbs. if it still won`t start now have someone try to start it while you hit the fuel tank bottom with something if it starts the pump is no good.
2answers
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Does bad spark plugs burn gas faster
First question is yes bad or worn plugs can burn more gas to generate the same amount of power.
Second question, you could fill up the tank and record the mileage, then fill it up again when it measures half a tank and compare.
If the gas gauge is working correctly it should take half the total number of gallons the tank holds to fill it up again. And the miles you drove divided by the number of gallons used equals your gas mileage.
2answers
Dash gas gauge stops showing proper gas level once it hits half a tank. Then gauge will fluctuate between empty (light will come on), full and anywhere in between but seems fine from full tank to half
If the trouble with the gauge started after you worked on it then you likely damaged or created a restriction to the movement of the sending unit. You will have to remove the tank and double-check your work.
My 1998 Hyundai Elantra will not start after running out of gas.When I put gas in it ,it would crank but it took a long time to start. I drove it 3 miles and it shut off. I cranked it and cranked it,but it...
Don't let the car run out of gas. Fill the tank and run until the tank is half empty. Again fill the tank.
By driving until you run out of gas, you are letting sediments/dirt collected in the bottom of the tank to enter the engine. Rather they will block the fuel filter. Then gas will not reach the engine.
Clean the gas filter and your car will run fine.
The same advice again. Don't drive until the tank becomes empty.
Just bought a '92 plymouth Acclaim with 37000 miles. It's in great shape but I'm not sure if the fuel guage is working. Only drove it home, less than 10 miles. Is the guage mechanical or...
There's a float inside the tank that the fuel gauge works off of. If you step on the brakes or accelerate hard it causes the gas inside the tank to slosh around and you can see the fuel gauge move when you do this. If you know the vehicle has gas in it, the best way to check if the gauge is bad is to drive around enough to where you should have burnt a noticeable amount of gas. If the gauge doesn't move, then there's something wrong with it.
Since the gauge moved when you braked hard, I would assume it's working properly because it picked up on the level change inside the tank where the float's at.
1helpful
2answers
S430/102k, mi/ Wouldn't start. Told to put car in neutural and 'rock it' 'Rocked' car, put it in park and car started and 'check engine light lit'Prior to the no start, wife...
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
Dies after running for awhile
you have vapor lock...try a fuel stabilizer...that should fix it
15helpful
2answers
2005 kia sorento Fuel Gauge says empty with 1/2 tank of gas.
Fuel sensor is not working well. Just changed mine today for the same problem.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
