Question about Toshiba Portege M200 Tablet PC
PC does not Power on, though indicator light is on
Switch On PC, Press power on, indicator light comes on, but PC does not power on to run, screen is blank, no fan starts, just quietness. Please Help what must I Do. It appears the voltage is being blocked from parts of the curcuit
  • kendogg88 Mar 27, 2009
    I have the same problem. I am pretty sure it is not the battery or the power adapter.
    Genius:
  • 2,785 Answers
Plz check with new power supply
Posted on Dec 01, 2008
My nephews kindle fire hd 2nd gen screen won't light up, need help
First thing to verify is that it is fully charged. You should see a green light indicating that it is charged completely. If it does not come one then, press and hold the power button for about 10 seconds. That may get it to start up.
Apr 24, 2015 | Amazon Kindle Fire HD
My tablet does not switch ON
Do a complete hardware reset, search goolge how to hardware reset your tablet.
Dec 10, 2014 | Archos 101G9 Android Internet Tablet
My IPad is stuck with the apple logo on a black screen while resetting to factory settings. No more movement now. What to do?
Don't forget to plug in the power. And again, press home button and on / off switch, till it switches off. Then press the on / off button, till the Apple logo comes back, then release the button. It can take up to a minute, before the screen comes on.
Sep 27, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Paperwhite troubleshooting
  1. Press and hold the Power button for a full 20 seconds.After the first 6 to 8 seconds, the screen will go blank, which is normal. Continue holding thePower button.
  2. After the 20 seconds, release the Power button.The charge indicator light will turn on after a few seconds.
May 03, 2014 | Tablets & eReaders
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
My Irola tablet will turn on but it will not load anything it just shows the Irola word on the screen then goes blank?
Most likely the battery is shot. If you could, try to power it up with the adapter supplying power. If this is successful it indicates that the battery is done for and no longer holds a charge. Most of the batteries on small, inexpensive tables only last for a couple of years. Yours may have used up it's life waiting in a warehouse. I have generally been unable to find replacement batteries for these tablets. There is a company in China that makes most of them as custom runs for small companies and does not stock replacements. You may also try to do a "factory reset" while the "powering up" logo is showing, find and press the reset button while using the power adapter for juice. If you manage to get it to run on the power adapter, and find that the battery is shot, there is little chance of portable use anymore.
Apr 15, 2014 | Coby Kyros 716829701508 Tablet PC
I have upgraded my tc1100 to 1.5Gs of memory. The description on the memory module is ( Super * Talent D400SBG/H STT DDR-400 PC3200 SO-DIMM Hynix 1G/64X8). The problem is the computer initially boots into...
It sounds like that memory should be compatible with your tablet PC. It may be a bad memory stick -- try to replace it with a different memory stick (preferably from a different manufacturer) and see if it still gives you the same problem.
If you didn't have this problem before you installed the new memory, a different memory stick will likely correct the issue. You can also try removing the new memory and see if the PC boots up like it should.
Dec 08, 2010 | Compaq tc1100 Tablet PC
I can't get any display on the screen of my pc.The power is working very well and all the led indicators are on. No sound during POST, and I have tried connecting a screen through the external screen port....
  1. please follow the following instructions i hope this helps
  2. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  3. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  4. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning
Jul 12, 2010 | HP Pavilion TX1320US Tablet PC
My hp pavilion tx1320us is not displaying any image, the screen comes up black
does it start....
if yes then press F8 before the Win screen comes...just after u press the power on button...
can u get the option to load in Safe mode...if yes chose Safe Mode
in Safe Mode if u get Desktop and can download from net
go to my website
www.sureshayyar.110mb.com
go to Download page and get Tuneup Utility and crack downlaod install both the software and crack and run a registry clean
Shut down
remove all power source, power/battery etc
remove all power cables
keep pressing the power on button for some time say 2- 3 mins....do ON OFF for some time....
reconnect battery/cables power ON
c if it works now...let it boot in normal mode
Dec 26, 2009 | HP Pavilion TX1320US Tablet PC
Powers on-indicator lights light up, motherboard fan runs, but do
try reseating the dimm ..
I don't see a listing in the manual for 5 beeps as you describe
Jan 04, 2009 | Lenovo ThinkPad X60 Tablet PC
Toshiba Portege M200 Tablet PC Logo
275 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
