Question about Toshiba Satellite A100-S8111TD Notebook
LCD Display flickers,then goes dark on bootup
Toshiba A100 AA8 TA7C 15.4" XPP mce sp3. Bios was updated march 2008. Desktop faintly visible when shining a bright desk lamp at screen! Suggestions greatly appreciated.
  • 345 Answers
Sounds like your display inverter has gone bad. You should be able to find an inverter for this model or if the computer is still under warranty I would find an authorized repair center for this brand of computer.
Posted on Dec 01, 2008
I have toshiba a100 .....i uploaded window7 but i m unable to find its display drive.....help me!!!
Systems: Toshiba A100/A105 laptops
Note: the Toshiba support site recommends strongly a BIOS update:
BIOS update for Satellite A100/A105, Satellite M110/M115, and Tecra A7Posted on: 04/10/2007
Updated on: 04/10/2007 15:51:53
In very rare cases, the battery pack of your PC may stop accepting a charge, i.e., the battery stops working and no longer supplies power to the computer. To minimize the risk of ever experiencing this problem, we strongly recommend that you download and install the latest BIOS by clicking the 'Downloads' link that will appear when you are finished reading Support News.
Try the Toshiba Software Installer for Windows 7(v1.0; 10-16-2009; 31.87M)
found at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Dec 15, 2011 | Toshiba Satellite A100...
Toshiba Satellite Pro A100 Screen goes black
Ensure first that is not a system problem, see if you still have power when screen goes off, check display settings, and eventually reinstall the system.
If it does not fix it then it may be an hardware fault.
Sep 10, 2008 | Toshiba Satellite A100-S8111TD Notebook
There are moving lines from up to down (it is like flickering) continuously during the monitor work
boot to bios and check if the lines can be seen. if the lines are visible, you have a faulty LCD. if not, update the display driver or graphics driver.
May 19, 2011 | Acer AL1916W 19" LCD Monitor
Screen flickers and goes dark u can see the image if u shine a flashlight on it. what could be the problem ?
It sounds like your LCD Backlight has burned out. You will most likely need to replace your LCD Screen, since you can still see a faint image.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 11, 2011 | Toshiba Computers & Internet
My screen went dark suddenly, when I try to restart my computer the screen is tinted red before going dark again. The screen is not completely black as there is letter visible underneath.
From what you are describing, it sounds like the inverter board is failing. This board sits under the LCD screen and is responsible for taking the DC voltage from the battery and AC adapter and converting that voltage to high voltage AC power for the backlight lamp that sits inside the lcd screen. Without that high voltage the screen goes dark. Most inverters do not fail right away, there are voltage fall offs etc. Inverters are approx. 15-20 bucks on ebay, for most laptops, they can be changed out simply by removing the bezel around the screen, unplugging the two connectors on the inverter and changing it out. In most cases except Dell, the inverter is just sitting in there and is not held in by screws.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Monitor Problems
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 30, 2009 | Dell Inspiron 9300 Notebook
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Flickering screen and no display
thats the complaint of LCD inverter circuit...if u dont know to open it,then dont do any thing better thing is go to the nearest service center of toshiba and try to repair it if thats failed. u have to replace with a new inverter circuit.dont try to repair urself...thats all.
Dec 13, 2007 | Toshiba Satellite P25-S507 Notebook
Toshiba a105 recovery disks display
well...if you are enrolled at a university you can get a student version of windows at an unbelievable discount.
Oct 02, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
