Question about Microsoft Streets and Trips 2008 for PC
In Visual Studio 2008
I am not getting Properties in Property Window.
Even i am not getting server side tools in toolbox.
  • 289 Answers
You will only see Properties (for controls) if a form is in view and this should be the same for tools. Open a form and see if that was the issue.
Posted on Apr 23, 2009
On our Dynamics RMS POS system, the database appears to be full. In the system administrator, under database properties, available space is 0kb and usage is 100%. I cannot find any function to allocate...
are you using MS SQL 2005? if so,
try this one:
1.open your MS SQL Server Management Studio,
2. connect to your data server and locate the database that has an issue on disk space
3. Right click that DB and select properties,
4. a new window will open, on the upper left part, select Files, now you may notice the settings for initial size of your DB.
5. on the autogrowth column, click the button corresponds to your database.
6. a new window will appear and displays options for your database autogrowth settings,
7. set your desired configuration, apply and your done,.
or you may check this blog:
http://blog.sqlauthority.com/2007/08/08/sql-server-2005-ssms-enable-autogrowth-database-property/
thanks
Sep 03, 2011 | Microsoft DYNAMICS RMS STORE OPERATION...
INSTALLATION REQUIREMENTS a compatible version of visual studio 2008 was not detected on the system. this update is designed for only microsoft visual studio 2008(ENU) product family,and is not...
The software you're trying to install is an upgrade from the Microsoft Visual Studio 2005 Professional edition. If you do not have that version of Visual Studio installed, you won't be able to install the upgrade.
However, I would recommend you downloaded the Visual Studio 2010 Express edition, it's fully functional and I used it for a long time before upgrading to the professional edition. To be honest the only feature I use in the professional edition is the addon system. Plus, the 2010 Express edition is free and available for anyone.
Feb 26, 2011 | Microsoft Visual Studio 2008 Professional...
How to disable command button in visual basic
  • tep 1 Open Visual Basic and select "Standard Exe" to create a new project.
  • Step 2 Add a button by clicking the square button tool on the right, and then clicking and dragging in the main window.
  • Step 3 Click the button once to open the "Properties" window on the right. Select the "(Name)" property, and type "myCmdButton" as the name.
  • Step 4 Double-click the button to open up the code-view window. Type the following in the white space under "Private Sub myCmdButton_Click()":
    myCmdButton.enabled = False;
  • Step 5 Click the blue "Run" button on the top toolbar of Visual Basic. Because you set enabled to "false" in the previous step, you will see your button grayed out, and nothing will happen when you click it.
  • Jul 07, 2010 | Microsoft Computers & Internet
    Cannot Install Visual Studio 2008 on Windows Vista
    From the message you get one infers that this is not the full program, but an upgrade to a previous version of Visual Studio. Even if you have a Visual Studio Express edition already installed on your computer, this update is not compatible with it.
    Hope it clarifies the message.
    Sep 04, 2009 | Microsoft Visual Studio 2008 Professional...
    I am trying to connect to a SQL Server 2005 DB from Visual Studio
    You must create an ODBC connection to your SQL database in the Windows Control Panel. Than you can call your ODBC connection via Visual Studio 2005. You can also create a DSN in Visual Studio 2005 and reference in that way. You will not be able to connect to an MDF but instead you have to connect to the SQL Server Service. Of course the username you use to connect must have access that will be created on the SQL server.
    Apr 13, 2009 | Microsoft SQL Server 2005 Standard Edition
    Visual studio instalation problem
    just take a look to this site:
    http://www.codeproject.com/
    you will get your answer there easily.enjoy it!
    Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
    Visual basic 2008 change location of user.config
    You can change the location by setting the Application.LocalUserAppDataPath property when the application starts.
    Hope this helps.
    Feb 18, 2009 | Microsoft Visual Studio 2008 Professional...
    Microsoft Streets and Trips 2008 for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
