I need hp cue status patch plz - Office Equipment & Supplies
Please i have vista and a message hp cue status
Posted on Dec 08, 2008
Since upgrading to Windows 7 and having to relaod the driver for hp deskjet 5150 I can no longer get my ink levels, ability to clean or calibrate the printer, etc. What do I need to do to get these...
You need to download a patch from HP. Go tot he HP Print Software Patch When Upgrading Vista to Windows 7
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77751-1&cc=us&lc=en&dlc=en&product=304431&tmp_track_link=ot_search
This patch will fix known problems with the following features and functionality:
•HP Print Status
•Toolbox
•Ink Levels
•Solution Center
•HP Scan (All-in-One)
•Front panel scan button (All-in-One)
Trust this is helpful. Please vote. :)
Dec 15, 2010 | HP DeskJet 5150 InkJet Printer
I just installed the f4180 and it keeps trying to re install
Has it completely installed , means are you able to print properly?
if yes, then you need to change the status of a service in services.msc named as "HP Cue device discovery" from automatic to manual , then restart the computer. After that it won't reinstall.
Jan 23, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
Error= hp cue status root must close system
hi,you can try restoring your computer to an earlier time,with the system tools located in the start menu.
Mar 04, 2009 | HP Pavilion dv6000z Notebook
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP CUE Status Root Error
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Aug 15, 2008 | Office Equipment & Supplies
Continuous error message
delete the hp cue discovery on your add/remove programs
Jul 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
155 people viewed this question
k24674
jasbo
jasbo
