Question about Mitsubishi WS-55809 55" Rear Projection Television
Problem with Mitsubishi 55 in. Rear Projection Television
Started today out of the blue. When you turn the tv on, the picture flashes on and off. It shows a solid black screen in between the flashing picture. This continues for about a minute or two, and then the tv works fine. Also, during this time the tv will not turn off with the remote or on the front of the tv. Any suggestions? Thanks!
  • 2 more comments
  • Janelle Kovash Emter Dec 02, 2008
    I just remembered that a few months ago the picture turned to a black and white picture a few times. When I turned the tv on and off, it came back on in color.
  • Janelle Kovash Emter Dec 09, 2008
    It worked fine for a few days and now it will start flashing after it has been on for a few hours. I read some where about the being two different cycles-one that bshows color and one that shows black and white alternating. Could this have something to do with the problem?
    Hitting the tv doesn't affect it. Pushing the reset seems to make the problem go away for about a day or two.
    No flashing lights.
    Genius:
  • 1,199 Answers
Sounds like you need to have the flyback on the circut board replaced! this is a commen problem and shold not cost much to replace! Warning High Voltage!
Posted on Dec 09, 2008
    Sergeant:
  • 314 Answers
You will need to have a service man come in and remove the dust that gathers. They are dust 'magnets'!! The dust will lead to a host of probs. Good thing you are not letting it go too far! Frankster016
Posted on Dec 02, 2008
  • 153 Answers
Try hit the set when it goes off and if it comes back when you hit it, than I think may be its something to do with the main board with loose components or coldsolder and needs resoldering.cheers
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls post back for any other indicators such as a flashing LED on the front panel, or the timer. Normally they would flash a certain number/sequence. This would tell us the general area of the fault. If none, would there be a clicking sound coming from the rear? Could you try to press and hold both the menu and input buttons at the same time and note light flash sequence.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 734 Answers
Hi,There is a problem in a condenser that supplies more power at to start your Rear Projection…. Need to be replaced as by any service engineer.
Thanks for using FixYa.
  • 495 Answers
Check if there is any loose connection in the TV circuit. It normally occurs when TV circuits are loosened. Also check for warranty of your picture tube.
5 Suggested Answers
  • 453 Answers
SOURCE: blue Convergence
go to main menu , selet advance setting , after that there is another menu where u going to find a convergence ajustment , select convergence adjustment , than choise blue , than after u access to blue color press the audio boton to do the blue , if u can't muve the blue color u going to have a repair service maybe ur stk or convergence ic are bad
Posted on Jan 16, 2009
welcomejee
  • 10594 Answers
SOURCE: blue cloud
That's OK, I been provided you technical info about TV problem.
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: Blue Line acroos bottom - 55' Wega rear projection TV
turn down the picture level the blue line goes away
Posted on Dec 03, 2009
SD Tech
  • 14553 Answers
SOURCE: Problem with the Mitsubishi WS-55315
ONLY1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on Sep 21, 2011
55" mitsubishi timer light flashes
I just had the same problem have you figured out how to fix the problem?
Nov 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Replacement of the green lamp(picture tube) in a Mitsubishi 55'' rear projection HD TV. Lamp is out. Other two (red & blue lamps are fine.) How to remove lamp/picture tube? Price and availibilty of...
You can probably purchase a smilar set on Craig's list for $300.00, at least that's what they go for in the Austin Texas area.
A new tube may be too expensive and difficult to replace.
Sep 13, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Blue cloud
Problem fixed by reading other post with same problem. Unfortunately Sony is not going to fix this problem.
Apr 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue cloud
Jan 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
13 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
