Question about Philips Televison & Video
Recently installed two Philco TB100HH9 Converter boxes. Both worked well at first then both lost a major local TV station within days and cannot reprogram it into the box. Have two other TV's without a converter box that are receiving excellent signals from the same antenna. How do I correct the boxes failure to bring in this station??
I just had a similar problem with this box - For the first month or two, I got the local NBC affiliate (KING-5 in Seattle) just fine on 5.1, then, after fiddling with my antenna setup, I lost it completely - NOTHING I could do would get it back. I tried a bunch of stuff - Multiple types of antenna, adding an antenna amp box, a handful of "homebrew" antennas - Nada. Yet all my other channels came in fine (although a couple were right on the edge - This box seems to need a "17" or higher on the signal strength - Some of my channels were reading in the 15-18 range, and suffering the "blockies" and sound dropout)
After hitting TVfool.com, found out that the KING digital signal is actually broadcasting on channel 48. Punched in 48.1, and there it was, clear as a bell, using nothing but a "wick" antenna (Basically, strip 4-1/4 inches of the outer braid off one end of a piece of co-ax cable, leaving the center wire alone, then plug the other end into the box) getting me a 23 signal strength. But a second or two later, the box is displaying "5.1" - Weirdness...
Reconnected a near top-of-the-line Winegard Yagi/Log-periodic antenna - VERY directional, and has some gain all by itself - and the signal jumped above 50.
Still couldn't "channel-up/channel-down" or punch in "5.1" to tune it, though - Channel 5.x was a "dead zone" as far as the box was concerned.
Re-did the "autoscan", and now, it's back to normal - I can channel-up/channel-down to it at 5.1, or I can punch it in as 5.1, or I can punch it in as 48.1, and it's all good.
So, try re-doing the auto-scan. Worked for me...
Posted on Feb 06, 2009
Codes for Philco DTv converter box TB100HH9 to work with RCA universal remote RCU800
RCA universal remote control have no set-up code to Philco. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 22, 2015 | RCA Televison & Video
Ge remote 24922 code for a Philco converter box tb100hh9
This remote control have no set-up code for Philco converter box. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Dec 24, 2014 | Televison & Video
Power light does not come on.
I had this problem with a Philips TB100HH9 and opened it up and it looks like a capacitor burned up because some white substance came out of it (82uF 200V). I ordered a replacement from Digikey and hopefully that will fix the issue.
Jun 24, 2011 | Philco TB100HH9
Need code for Philco Digital to Analog converter for universal remote
most univeral remote you can push aux or whatever one you want to program it to the push in set-up and hold till it light stays red then push channel up till light goes out then push set-up or the button for it to be saved to,to save the code for the converter. hope this helps, i cant tell you a code because i don't know what brand your remote is but i know what i said will work. may take you a few trys good luck
Dec 30, 2010 | Philco TB100HH9
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Converter Box Philco TB100HH9 / GE Remote 84964
Yes, only the company that supplied you with the box. Call your cable or satellite provider. They will help you on the phone.
Mar 24, 2008 | Televison & Video
Televison & Video Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
