What washer and dryer have the least problems, I need a very basic set that is quiet, cleans well and don't bounce or viberate. I have a maytag that gets out of balance EVERY load and I have to be home, and move the clothes around every spin. If this is fixable I would keep it but I am hating it everytime I use it...any suggestions
  • Washing Mach... Master
  • 3,463 Answers
Hi.
Whirlpool are very good, but they are quite wide no problem if you have plenty of space.
Check out their website.
www.whirlpool.co.uk
Please leave feedback.
Thanks
Posted on Dec 01, 2008
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
Maytag MGD 9700SQ. When I press start, the sensoring light clicks on and that's it. I've cleaned out the lint, cleaned the sensors with alcohol. Will clean the vent, but it seems like a basic fix....
Hi Jamie: After checking all of this and if it still dont work you will need to put in a new control board.
Plug cord into live electrical outlet. Check for proper voltage.
Check fuse or reset circuit breaker.
Push any key to turn ON the clothes washer and press the Rotary Cycle Selector knob to start the clothes washer.
Close door and push the Rotary Cycle Selector knob to start the clothes washer.
Check to see if the clothes washer is in a pause, soak or suds period in the cycle. Wait briefly and it may start. If washer is in suds period, SU and DS will display alternately, instead of the time remaining.
Check for restricted drain system. If there is an electrical problem in the drain system, ND error will occur after 15 minutes.
Check water supply.
Check the line screen and water valve screen.
Check for loose connections at machine control board terminal connections
Replace machine control board.
In this link, with your model could find parts replacement:
- Maytag-Parts/Dryer-Parts/Model-MGD9700SQ
- partsearch/model.aspx?model_id=5140219
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 06, 2011 | Maytag Washing Machines
My Maytag "Dependable Care" dryer timer is not functioning and the dryer will not work. Will simply replacing the timer fix the problem? The washer/dryer set has been wonderful, but is about 12yrs old. ...
Don';t throw the dryer away yet. Check the circuit breaker in the electric panel to see it it has popped. If it checks out ok then check where you plug the dryer electric cord in. There may be an overload pop-out button on the receptacle. If there is, reset it.
Oct 09, 2010 | Maytag Clothes Dryer Almond Timer Knob...
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Maytag washing machines and Dryers replacement keys.
LPD will help you out they provide an excellent service and the cheapest in uk. www.lpdlpd.co.uk
phone number 0121 580 0880
Mar 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Quiet Plus 2 dryer
I can't speak for which one is best, but I I can help you fix the no heat problem.
I am assuming it's electric heat. If it is, I bet the element has failed. If you know how to troubleshoot with a volt-ohm meter, I can walk you through the repair.
Let me know if you have the wiring diagram, or can find it on the appliance. Also let me know if you know how to read one.
Feb 01, 2009 | Dryers
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
