Question about Logitech 967437-0403 Keyboard
Logitech cordless keyboard erratic after cleaning keys
Logitech cordless keyboard keying wrong [ not exactly erratic] This happened after I cleaned the keys [ without opening the set ]. This is the first time this has happened in 6 years of usage Mouse is ok. Tried to reset by poking into hole at back, rebooted with Original CD each time Changed Batteries Tapped keyboard to check if anything is stuck under keys But no results
    Problem Solver:
  • 47 Answers
Seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Posted on Dec 01, 2008
ARROW KEY,DELETE KEY WILL NOT WORK IN COREL DRAW ???WORKED FINE THIS MORNING
if these keys works fine on other software then that means there is nothing wrong with your keyboard. if this happens only in Corel draw then you should check software shortcuts under preferences in edit menu! i hope it helps!
Mar 04, 2011 | Logitech Cordless Desktop MX 3000...
Keyboard sticking
Clean the keyboard. Most of the keys can be safely "popped" out using a nail file or other thin lever. Don't pop out the larger keys, like the space bar, because they have a small wire spring in most models that can make them difficult to reinsert properly. Use canned air, a Swiffer, q-tips, or other methods (nothing wet, but a damp cloth that doesn't drip is OK) to get the obstructions cleaned away and then put your keys back.
Mar 01, 2011 | Logitech Cordless Desktop MX3200...
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
My logitech wireless keyboard won't type. i
go to logitech support, download setpoint software and follow instructions on setting secure connection. i just did it with mine and keyboard got fixed. your symptoms should be that the qwerty keys dont work but the multimedia, clock and function keys are working. the setpoint software will take care of that.
Nov 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
Hello expert
try cleaning it before you mess with any settings.
Cause:
Your keyboard or number pad may collect dust and other deposits from regular use. Occasional maintenance helps keep the device looking clean and functioning properly.
WARNING: Before cleaning any electrical device or equipment, ALWAYS remove the device from its power source.
Solution:
  • For cordless keyboards or number pads, remove all batteries before cleaning.
  • For the diNovo Edge (a rechargeable keyboard with a built-in, non-removable battery), or any other similar device, switch the keyboard OFF before cleaning.
  • For corded keyboards or number pads, shut down your computer and disconnect the keyboard from the computer before cleaning.
Keyboard and number pad cleaning suggestions:
  • Use compressed air to blow dust and other debris from between the keys. Logitech suggests using an air duster squeeze bulb specially made for keyboard cleaning to limit the force of the air pressure.
    NOTE: Avoid using high pressure air hoses and nozzles. Excess air pressure can remove keys or cause other damage to your device.
  • Use a small tipped vacuum cleaner to remove dust and other debris from between the keys. Logitech suggests the use of a small tipped vacuum cleaner specially made for keyboard cleaning. Many come with USB power cords and can run off your PC or laptop.
    NOTE: Avoid using vacuum cleaners other than the type previously described. An excess vacuum level and/or large vacuum tip can remove keys or cause other damage to your device.
  • Use a dry, lint-free, non-abrasive micro-fiber cloth to gently wipe clean the surface of your device. Logitech suggests using cloths which are specially made for keyboard cleaning.
    Note: Avoid using dusted disinfectant cloths or cloths dampened with liquids unless specifically designed for keyboard cleaning. Many cleaning solvents, chemicals, and other liquids can cause electrical and/or material damage your device. This includes leftover residues which can eventually damage your device over time.
Additional information:
Many consumer electronics stores and online re sellers offer third-party computer cleaning kits which include dry wipes, swabs, air duster bulbs, and micro-fiber cleaning cloths. Some higher-end cleaning kits come with keyboard vacuum cleaners, and/or product-safe disinfecting liquid for dampening wipes, for use in disinfecting the surface of the device. These liquid disinfectants are supposed to be non-conductive electically; quickly evaporate from the sevice and leave no residue. Logitech suggests you make sure these characteristics are plainly stated and guaranteed on the product package. These specially made keyboard cleaning kits are highly recommended.
IMPORTANT NOTES:
  • DO NOT pour any liquids onto the device.
  • DO NOT submerge the device in any liquids.
  • DO NOT use a dishwasher, ultra-sound cleaner, or any other washing machine to clean your device.
  • DO NOT remove keys from the device.
  • DO NOT use cleaning solvents. Many cleaning solvents contain caustic chemicals which may cause damage your device.
  • DO NOT use drying machines, fireplaces or ovens (even set at lowest temperature) to dry moisture from your device.
Removing keys; submerging or pouring liquids on your device; using washing machines; exposing your device to excessive heat; or using caustic cleaning solvents may cause permanent damage to your device and will void the warranty.
Feb 27, 2009 | Logitech Cordless Desktop MX 5500...
Cordless keyboard keys
You should open the keyboard and clean the contect point of "k" key .If you have done this then check continuity of "k" key with other keys it must be broken.
Hope this solution works.
Mar 14, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Logitech keyboard wireless
You need to go to Start -> Settings -> Control Panel & find the "regional & language settings". Set the country and related settings to wherever you are (as you're currently using a foreign setting).
Dec 01, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech 967437-0403 Keyboard Logo
692 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
