Question about GE Microwave Ovens
Microwave will not heat any thing.
Also I droped the plate and broke it does it need the plate to heat it is 2 years old mode # Jes1451bj 02
  • kq4clham Dec 01, 2008
    Yes I here the fan and light does work.The turn table works at times but not allways. I do get a loud hum and it only pulls 6.5 amps when it hums. My old wave would pull over 16 amps when it worked and heated ok.
  • 905 Answers
The plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Posted on Dec 01, 2008
  • jason Dec 01, 2008
    the loud hum could be the transformer going bad also , i would say you are better off getting a new one
  • 905 Answers
Why
    Sergeant:
    Champion:
  • 338 Answers
The turn table plate helps the microwave heat evenly. What happens when you turn the microwave on? Does it light up and the turn table turn and do you hear the fan going? If all that is present then you need the mag cap diode. however if you do not hear much noise from it and just the light turns on and turn table turns then you have an interlock problem. Let me know if you need further assistance.
  • Robert Artiaco Dec 01, 2008
    you should replace the magnetron, capacitor and diode. also replace your turn table motor
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
Sep 24, 2014 | Kenmore Microwave Ovens
Microwave plate turns but does not heat anything
The magnetron is bad. This is the radar wave producer that excites molecules and makes things cook. It is a replaceable part but you may find purchasing a new one is more desirable. Why? A magnetron for a popular model microwave that is 1-3 years old will cost about $50-60. If it's an old one it can cost $189 and hard to find one available. And if it was mass produced in China with a no-name brand you probably won't be able to find parts much less customer support. Also, if one component has gone bad it won't be long before another goes bad. Good luck.
Mar 14, 2014 | Candy MIC201EX 800 Watts Microwave Oven
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Micro is turning on ok and working but not heating up,what would cause that? light is on ok and plate is turning, just not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Jan 28, 2010 | Sanyo EM-G2585W Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Need glass plate for 24 year old Goldstar microwave model ER4010
The original part number was 2B70335A then it was 30QBP004, but these are no longer available.
Jan 14, 2009 | Microwave Ovens
Microwave won't heat.
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 30, 2007 | Maytag UMV1152BAS Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
Microwave Ovens Logo
443 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
