Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher Paykel F1 error / double dishwasher drawer
Our dish washer is beeping and flashing F1. It appears the lid was not closed completely based on a plate obstructing it's proper closure. There was some water under the lower unit.
  • Anonymous Dec 01, 2008
    F1 is the flood sensor... water is leaking from one of your units. Check and see if the top is seal during running.
  • Advancedwest Dec 01, 2008
    Ran the bottom unit and the top filled with water. Than, the F1 alarm started to flash on both units. Tried to drain but the beeping error will not go away. Any ideas on how to fix?
  • 78 Answers
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Posted on Dec 01, 2008
F1 and beeping
F1 means the drawer lid is not closing properly - (lid seal leaking) which caused water to splash out when you started the wash cycle. The flood circuit on base of dishwasher housing (under the bottom drawer) has tripped. You will have to find the source of leakage and also dry the base of dishwasher housing. Make sure the dishwasher is unplugged form mains socket when you work in it.
Jan 16, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel Dish Drawer: I flooded it by using wrong soap. It was flashing F1 but I solved this by drying it out after removing the bottom drawer. That problem is solved but now the top drawer is...
Most likely the lid seal is dislodged and is obstructing the bottom drawer. Need to manually operate the lid seal actuator yoke and motor to bring the seal back to normal position. Can be messy.
Will need to get the bottom drawer out from housing and work on lid seal assembly located in the main housing.
Sep 25, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our fisher and paykel dishdrawer won't wash. It comes up with F1 and flashing light on control panel.
the dynamo dishwashing stuff has caused foaming which reached the base of the dishdrawer unit causing the flood switch to trip. This gives F1 error.
Not sure how much foaming has occured.
Best to turn off power and take power cable out from socket. then empty the drawer using towels. pull out the bottom drawer and wait a day or so to let the foam disappear from the bottom of dishwasher (under the bottom drawer). Connect the power and see if F1 had gone. If not, you need more work. Post a comment based on the above suggestion and I will guide you further if required. Always use Finish dishwasher power only (recommended quantity) as the drawers are small and don't need much detergent.
Dec 27, 2012 | Fisher Paykel Dishwashers
Maytag A7800 washer wont start agitation with lid closure
you need a new lid switch assembly, which will run you about 30 - 40 bucks
Jun 05, 2012 | Maytag Washing Machines
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
3 problems: 1. lower drawer is hard to close; seems to be sticking on something. 2. lower drawer retains water (2 inches) after completing a cycle. 3. F1 fault code on both drawers with alert...
ok where to start, first thing the bottom draw is hard to close because they use 2 little motors on either side to pull a lid with a seal on it down on top of each draw when u start it to keep the water in, if its hard to close the motors are damaged and arnt lifting the lid back up when the cycle finishes making it hard to open and shut, now the F1 fault means the filter circuit board in the base of the machine has been activated basically a flood sensor (and controls minor components ie lid actuators), the unit should beep and flash and go spaztic and you should hear the drain pump come on continuously til u turn it off at the wall thats its way of trying to stop a leak by removing any water it can but will not actually remove the water from the base where the switch is, you will probably find it will work now as the water will have dried and stopped triggering the switch but wont stay like that for long, that machine has major issues its leaking bad from somewhere and id say it leaked onto the lid motors and fried em, the parts you will most probably have to replace is the filter board in the base, both bottom draw lid actuators (small motors), probably the bottom draw lid if you damaged the seal pulling the draw in and out and whatever is leaking and if any other componets where damaged by water, so if its outta warranty id go buy a new 1 with 5 year extended warranty
Oct 26, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
My DD603 is flooding onto the floor and F1 is flashing/not turning off.
You have probably figured out by now that the only way to stop it is to unplug it. The F1 code means that the Mains Filter flood sensor has been activated. There are a few reasons this may occur. 1. there was a large pan or dish that prevented the lid from closing fully, thus flooding. 2. the lid actuators, motors, did not close the lid completely and they need replacing. 3. the Link Support (holds the wires and hoses in place behind the drawer) has broken and is impeding the lid from closing fully. It and the lid would have to be replaced. These are the normal causes for the F1 error code. You will need to get a Tech out to have a look to determine the cause. Good luck.
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Showing f1
The f1 fault is cased by a leak on the dishwasher.
It is activated when water gets to a dangerous level in the base of the appliance near to the PCB.
The main reason this happens is putting cups on the drop down shelves and when the lid comes down to seal the drawer it can't and leaks. If you look at the drawer when open there is a lip around it, if anything is proud of this lip the lid will not shut properly.
To rectify this problem you will have to disconnect the power and remove the bottom drawer and the dry up all the water in the base. If you leave the appliance long enough it will dry out by itself.
Once you have done this and the problem still comes back you will need and engineer as there is a problem with the lid motors or the seal’s.
Good luck hope this helps..
Mar 21, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
938 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
