Question about HP Officejet 5510 All-In-One Thermal Printer
Hp5510--will fax, bukt when it prints, the sheet is blank.
Faxes, but won't print. The page is blank
    Problem Solver:
  • 6 Answers
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
Posted on Dec 01, 2008
Printer prints a page then sends thru a blank page... prints page then blank page...
I posted this video a long time ago...hope it helps!
utube.png You-Tube video "WrxT2_T6JVA" placeholder (do not delete) utube.png
Good Luck!
Jan 02, 2010 | HP Photosmart C7280 Printer
Printer does not print documents that are more then one page long. all I get is a blank sheet with a page no after the first page which prints ok
If you print out a Test Page (Start -> Control Panel -> Printers & Faxes -> Right Click on your printer entry -> Properties -> Print out a "Test page")
If that does not print please follow these steps: Remove the printer USB cable from your PC -> Restart your PC -> Log back onto your Profile -> Click on Start -> Control Panel -> Printers & Faxes -> Delete all printer entries -> Restart your PC -> Log back onto your profile -> Plug the printer USB cable into the back of your PC -> Go into Printers & Faxes -> Right Click on the Kodak AiO entry -> click "Set as Default" -> Now try to print.
Oct 20, 2009 | Office Equipment & Supplies
Printer feeds blank pages.
often in the Printer properties, there is a tickbox, to feed a blank sheet between print jobs. this is to assist in keeping print jobs seperated on busy printers.
Here is the way to change the setting on a single print job:
  1. Click the Start button
  2. Point to Settings
  3. Point to Printers (Windows 2000) or Printers and Faxes (Windows XP).
  4. Right-click the HP LaserJet driver you plan to use (2420)
  5. Click Properties .
  6. On the Advanced tab, uncheck Separator Page.
  7. Click OK to return to the Advanced tab.
  8. Click OK to save the settings.
Making the change a permanent thing For All print Jobs on this printer:
  1. Click the Start button.
  2. Point to Settings .
  4. Right-click the HP Printer you want to correct the settings to.
  6. On the Advanced tab, click Printing Defaults .
  7. Change any of the settings on the tabs. These settings become the defaults for the printer.
  8. Click OK to return to the Advanced tab.
  9. Click OK to save the settings and to close the printer driver.
Sep 23, 2009 | HP DeskJet F380 All-In-One Printer
Hp2420 when i print i get a blank sheet first then the printed one
Check the printer settings to see if the printer was set to add a blank page to the beginning of all print jobs.
This procedure changes the printer settings for a print job:
To change the default settings for your printer, use the following steps for Windows 2000 and Windows XP computers.
Sep 10, 2009 | HP Office Equipment & Supplies
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
BLANK PAPER
If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward. You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its “copy” function, or print an activity report. If all is well on your end, the problem must be with the sender’s machine.
If, by any chance, you’re using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that’s the case the heads won’t print on the side that isn’t heat-sensitive.
Thanks for using Fixya.
Apr 16, 2009 | Office Equipment & Supplies
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
HP Officejet 5510 All-In-One Thermal Printer Logo
399 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
