Wavy diagonal lines appear on the TV screen and will not go away. Does the lamp need to be replaced? We know it is not the Cable or DVD.
  • stollme Dec 02, 2008
    We have had this TV set now for 5 years and did not have any of this prior to a few days ago. What do you suggest we try first? We have unplugged the TV. We have had the cable checked over the phone. Do we get a new power strip and if so, what might be one you would recommend? Thanks for all your help.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Often, what you described as way lines could very well be AC component riding on the video signals. Based on this, areas that could be explored are:
  • any other devices on or near the TV such as wireless phones, lamps, even the DVD, cable box and others. Pls try using a different outlet;
  • try using a filtered power strip or an appropriate voltage regulator, something like what is used for desktop computers but with the power rating appropriate for the TV;
  • try plugging the TV itself in another outlet;
  • temporarily remove the cable connection and determine if the wavy lines persist;
  • in some worst case scenarios, this could be a faulty capacitor in the power supply of the TV;
  • still it could be as simple as RCA to RCA cables that are flimsy and/or with inadequate shielding and/or running parallel to power cords.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 02, 2008
    Glad to be able to give you ideas and appreciate the rating too.
    Filtered powerstrips would look like image below.
    They are normally available from most audio/tv or electronic shops stores. At times equivalent could also be found in computer shops.
    While they would look like ordinary extensions, it must have surge protectors and filtering built-in.
Static lines on screen
Just adjust your cable while looking at the screen, the diagonal lines will slowly disappear
May 29, 2017 | Samsung DLP HL-P5663W 56" TV
Wavy snow lines on samsung
are those lines appear in the screen either you hooked up a source like a dvd player and also during watching tv channel?.if so, locate the t-con board which is mounted covered with metal shield. tried first with re seating the LVDS cable connected to the board to fix loose connection, remove and then re attached to the connector terminal.hope this can help good luck.
Sep 07, 2012 | Samsung Televison & Video
Sharp lcd tv does not have clear picture.
Try it on different inputs like out from a box, direct cable or a DVD player etc to see if problem is isolated to one input on the set.
May 24, 2012 | Sharp Televison & Video
Wavy lines and no stereo
this is a tv problem, needs to be chekout, normaly is TV HV circuit defective, and shows the some lines. go to repair shop to repair.
Nov 22, 2009 | RCA DRC8030N
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Diagonal lines through the picture.
I've found the lines caused by the digital board before. Unfortunately it is expensive. I'd recommend running it on HD and it will bypass the faulty circuit. The lamp light flashes telling you the lamp is firing up. As the lamp ages, it will take longer and longer until it fails.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Replaced lamp in WD-52825 but still no picture. Lamp indicator on.
the DM board has gone bad. it is not the 4 100uf caps on the board. it is surface mount parts. it this board has failed then the FMT board is not far behind. the chassis needs to be rebuilt. www.tv-techs.com
Aug 29, 2008 | Mitsubishi WD-52825 52" Rear Projection...
HELP HELP HELP
lines may be caused by AC pickup. if so, usually the lines move slowly up the screen, and two major sets are usually displayed. wavy lines may also be caused by a local TV station transmitting on the same output channel, either 3 or 4. If you can change the output channel, this may help. Also, try disconnecting all cable or satellite signals and see if the problem goes away. May be an adjacent channel bleeding over. If the lines go away when putting the dvd on pause, the problem is probably in the dvd power supply. Cool the unit down by unplugging it for a while and then try it. If the problem goes away then, separate the dvd player from other devices to prevent overheating
Oct 30, 2007 | Protron PD-800 DVD Player
Sony with diagonal lines
Is it a composite(yellow plug)video input? an HDMI input? What if you switch the output of the cable box to another input, Make sure its not the cable box first. If it happens on another input then the cable box or the connection wire to the tv from the cable box is bad.Good Luck Ps Please rate this thread
Oct 18, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Televison & Video Logo
Top Televison & Video Experts
