Question about Sony (CDU5212) Internal 52x CD-ROM Drive
Uninstalling cd rom driver
I am trying to replace my current cd drive with one from our other computer (since it is getting a new one).. When I try to load the driver with the software it tells me to uninstall the old one.. Then it leads me to the uninstall window with all programs.. I have gone to the properties on the driver and uninstalled there and it just tells me it has to restart the computer now.. But then the driver is still there and I get all the above messages..
I have a 2002 dell computer and it doesn't have a dvd player so we are just trying to install a dvd player instead of a cd rom... I am sure it is quite simple I am just a lost...
    Master:
  • 37 Answers
Uninstall daemon tools and any other DVD/CD related tools (Remove StarForce, Remove Securom). One by one, with a reboot each time
Posted on Apr 08, 2017
bunnydawg
  • 5158 Answers
SOURCE: my SONY DVD+RW DW-56A won't burn a DVD
I am suspecting that you are running into a copyright issue that wasn't removed when they made the copy.... or the copy was corrupted... will it play back on your machine ?
Robert
Posted on Dec 20, 2008
  • 1257 Answers
SOURCE: CD-Rom Cdu5212 not working
Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on May 26, 2009
arpit47
  • 162 Answers
SOURCE: DVD rom restarts xp home
It is the problem of your motherboard check it out to workshop
Posted on Jun 29, 2009
halbrook
  • 560 Answers
SOURCE: My Vaio DVD/CD drive Sony DVD RW DW-U14A hasn't
Hi. Check the transport mechanism of the laser head. The transport can get stuck with dust, hair or vibration. If the transport is stuck, the drive still appear but can't read the CD because the lens is not moving properly.
Clean the area around the lens with cotton buds (be careful not to scratch the lens). Move the lens mechanism away from the center (use a plastic paper clip, slide gently). Place a DVD/CD disc and reboot your laptop. The DVD will auto align the drive during boot-up.
Good luck.
Posted on Aug 06, 2010
bronk50
  • 27725 Answers
SOURCE: program tries to load every .dll file on my hard drive upon booting up
Dll errors occur due to various reasons incomplete installation or removal of a program, missing, corrupt, or incorrect .dll file paths, and more. Failure to fix these errors can result with severe PC problems click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box then select check now start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer also download a registry cleaner http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Hope it helps.
Posted on Dec 27, 2012
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Will not recognize cd's but plays and records dvd fine
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device also scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Dvd drive noisy put in dvd go to my computer driver is showing but wont play driver ejects
1. Try a different cd or dvd to see if it's reading any dics
2. Boot computer and try again
3. Uninstall the dvd drive from your computer (windows xp machine) , Right-click "My Computer-icon" -> Manage -> Device Manager -> DVD/CD-rom Drives -> right-click and select uninstall Restart the computer and it should install the drive again automatically Try reading the discs again
5. Update driver if available, see manufacturers website for driver updates
6. Try the dvd drive in another pc (if possible)
7. Propably faulty drive, replace the drive with a new one
Mar 06, 2011 | Computers & Internet
WHEN I TRY TO INSERT A CD, IT REFUSED WITH HEARING OF ROTATION SOUND, WHY?
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Jan 07, 2011 | Computers & Internet
Cd rom not working
Have you tried unplug cd rom drive then reboot and plug it back in should initiate the found new hardware wizard if it does not initiate the wizard try control panel add new hardware wizard and follow the prompts you will get to the screen asking you if you have already connected the hardware click next will open a screen with all your connected devices hopefully your cd rom drive will be listed if not it could be a power\lead problem or a driver problem
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 03, 2010 | Dell Computers & Internet
I can not get my Cd Rom to read a disk
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
Nov 26, 2010 | Acer (91.47A37.001) CD-ROM Drive
Cd drive wont open
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
My disk drive is no longer recognizing that there is a disk in it. Is there any way I can fix it at home?
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
Nov 24, 2010 | Compaq (120192-B21) CD-ROM Drive
My dvd rom is not working, how do i fix ti
hope this helps
Nov 24, 2010 | HP Pavilion dv2000 Series Laptop Full...
Hello, My problem is that the drive does not eject smoothly. It has to be given a gentle push to close and has to be pulled to open. What is the solution for this problem? The drive burns and play disc...
hope this helps
Nov 23, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
Sony (CDU5212) Internal 52x CD-ROM Drive Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
