Question about Microsoft Xbox 360 Console
Bad signal wireless router
I have a bad signal on x box live ,what adjustments do i need to make to my router(d link model 604t )in order to enhance my signal ,help .....
  • 3 Answers
I have the bst solution for you dont use wireless connections i dont wired connections give u better bandwith so the online games load faster
Posted on Dec 01, 2008
ROUTER DOESN'T SEND WIRELESS SIGNAL
It may be the devices? Are the LED's blinking? Do you see the Linksys in Available Wireless Networks on the computer? You didn't mention the Make, Model of computer and the OS you are using?
Jan 01, 2013 | Linksys Wireless-N WRT150N Router
Tip
How to improve signal strength on a wireless network
The success of a wireless network depends on the signal strength. A strong signal is required so all networking devices can communicate with each other. A weak signal causes low bandwidth preventing communication between hosts and causing network disruption. <br /> <ol> <li>Pay attention to router placement. It should be away from walls, floor, and glass and metal objects, all of which disturb wireless signals. If possible, place the router in a central location.</li> <li>Change your router's standard antenna to use a high-gain antenna that sends signals in one direction. This way signals can be focused in the required direction. Standard antennae send signals in all the directions, which may not be desirable especially if the router needs to be placed next to a wall.</li> <li>Use a wireless repeater, the device that enhances range of a wireless network.</li> <li>Change the channel on which the router is functioning. Similar to radio stations, routers function on different channels one of which may give better performance than the other.</li> <li>Ensure the network card installed in the hosts is capable of receiving and sending signals to the router. In this respect, using equipment from one manufacturer is better.</li> <li>Check the vendor's site regularly for latest updates, performance enhancing tips and fixes.</li></ol> if you need more information regarding improvement of wireless network, visit<a href="http://www.microsoft.com/athome/setup/wirelesstips.aspx"> THIS</a> site.
on Dec 13, 2010 | Computers & Internet
I can pick up a signal from my neighbor with a laptop but not my coby tablet. would a wireless router work
You will need a reapter instead of a router With a router you would have to connected to the HIgh speed directly ,But with a reapter you will take a weak signal and enhance it to a strong one you can get a reapter from Amonzon .com or follow the link I have provided to the device
http://www.amazon.com/Amped-Wireless-Wireless-300N-Repeater-SR300/dp/B004NBL9WK/ref=sr_1_1?ie=UTF8&qid=1314371697&sr=8-1
Aug 26, 2011 | Computers & Internet
I have a NetGear WGT624 Wireless Router and live in a 800 square foot apartment and have trouble with speed in the apartment. Sounds crazy, but doors open, two drywall walls should not have this type of...
Hi, one thing you could try is raise it. if you dont have concrete ceiling you shold see a consistent improvement in signal strenght.
PS: open doors (if they are not steel ones) shold not interfere with signal, but drywalls has an internal metal frame that affects a lot wireless signals.
I hope i could help.
Jul 27, 2010 | NetGear WGT624 Wireless Router
I have laptop and would like to make a wireless connection to my laptop/pc using my wireless router.Right now i have a desktop/pc,dsl modem and another desktop/pc hard wired into it.Name and model# of my...
In order for you to make computer to wireless with your existing wireless router, first thing that you need here is a wireless adapter that will serve as a receiver for your computers to pick up the signal from your router.
Once you already have a wireless adapter on your computer you can now detect the signal of the router and connect to it and that should be fine after that.
Jul 02, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Code to enter a cod
if it is a newer router there is a code on the bottom or back of the router you need to type in in order to connect wirelessly
May 09, 2010 | D-Link DI-714P+ Enhanced 2.4GHz (802.11b)...
I'm trying to connect vista laptop to d link dsl-604t router wireless which has a mac os 10.5 with password using it
On Vista, when you "view available networks", is the SSID (that you configured into the router) listed as an available network?
If so, click to select that SSID, and click CONNECT.
Nov 06, 2009 | D-Link DSL-G604T Wireless Router
Since upgrade MacBookPro to Snow Leopard it will not wireless connect to D-Link DSL 604T. Is there a firmware upgrade for this wireless router for use with MacBookPro running Mac OSX 10.6.1 please? My...
When you try to connect to the wireless network, Do u get any error message ?
You said that your other wireless is working properly.
that means the router is working properly.
Check the wireless security settings of the router. Do not change the wireless settings, just check the wireless settings.
You will need to open the Web Interface of the router.
Click Here for more info
Oct 22, 2009 | D-Link DSL-G604T Wireless Router
Wireless Acquire network address problem
belkin has a wizard to help you with the wireless setup.
maybe you have a security option turned on. check the router for security options.
make sure its on disable security to check the wireless part also check to see if the wireless option is turned on.
Jun 25, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
138 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
