Question about LG M1910A 19 in. LCD Television
Not able to connect my lap top to to the monitor
I have a 19 inch flat panel TV and though the TV has a serial port to connet to external devices like computer, when i connect my laptop to it it gives me a msg no signal input. Kindly help.
  • 61 Answers
The laptop should have a special area under display properties and goto settings you should see 2 screens if not it might need the top addres bar settings change and you will have to choose which screen is the primary and secondary and if you click to verify the screens the screens should have a number of which is the primary is 1 and secondary is 2 on the screen and if you have the icon to change these setting near the clock then try right clicking it and it should be up a option screen and it should should have the option to output to monitor and screen....
Posted on Dec 01, 2008
Is there an HDMI input on this tv? And if so, where?
No,there are no HDMI ports in this tv design.This lower end of LCD tv made especially for Target it only get to resolution max 720p,so no HDMI ports.Only can connected devices as RCA component cables Yellow Red White only as for AV input for external devices attactments.
Dec 28, 2010 | TruTech PM1919BXA1 19 in. LCD TV
I have a samsung synmaster 712 n monitor when and a dell inspiron computer lap top . when i plug monitor into lap top samsung light blinks and no signal on screen from lap top
Did you use the combination keys of your laptop Fn and either F5, 6, or 7 depends on brand to select internal/external/both? You also need to make sure that the video resolution feeding the monitor is at native resolution setting.
Failed TV and Monitors:
Oct 15, 2010 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Ho do i connect my laptop to my flat screen samsung tv
There are 3 ways ways to do this from the left side of the laptop.
1) S-Video-out jack [Connects an optional S-Video device such as a television, VCR, camcorder, overhead projector, or video capture card.]
2) External monitor port [Connects an external VGA monitor or projector.]
3) HDMI port (select models only) [Connects an optional video or audio device such as a high definition television, set-top box, DVD player, or any compatible digital or audio component.]
Your TV will have one of those interfaces. You just need to look at your user manuals for both the Laptop and TV
Take Care
Oct 03, 2010 | HP Pavilion dv9000z Notebook
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
How to connect my dell dial up modum to lap top
Your dial up modem needs to be ab external modem.
You can not use an internal modem from another machine unless you create a network and share your connection.
If you have an external modem then connect the modem to the available port on your laptop and let plug and play take over. If you do not have a port on your laptop and you modem has a serial port you will need a usb to serial adapter which you can get at Radio Shack.
Jan 09, 2010 | Ultra Computers & Internet
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
TV TUner external not starting up
Safe mode
Power saving off
restart normally
Jan 30, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Blank screen on my monitor
kindly check display settings in your laptop.....
Dec 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Jul 31, 2007 | iLO V27DMBX Television
LG M1910A 19 in. LCD Television Logo
179 people viewed this question
Computer Repairing
Computer Repairing
