Question about Logitech QuickCam Webcam
Hissing noise I have a hissing noise or white noise that occasionally pops up form time to time when using this web cam over skype. What may cause this problem? Thanks...
    President:
  • 8,637 Answers
This is mostly caused by the speakers being turned up causing feedback. If you use headphones it should eliminate this problem.
Hope this helps. Bud
Posted on Feb 01, 2009
What makes my 2001 chevy silverado airconditioning make a hissing sound when my air is on
Check the bearing in the end of the blower motor. They go bad and make a noise and over time will start rubbing and squealing like crazy.
Jun 12, 2017 | AC Cars & Trucks
Hi I have a geberit cistern 222.013.00.1 with hissing noises and tank keeps topping up occasionally
wait for the new washer/ valve to settle in
or turn down the inlet water tap a bit
what does this really mean
tank topping up with water and re filling occasionally
in the wrong way or too tight or the wrong part ?
Nov 09, 2016 | Home
When starting it makes a popping sound.
You have to find out where the popping sound is coming from, it can be a bad intake or exhaust valve or bad lobe on the cam, Ignition timing, rich or lean fuel mixture, or just a simple vacuum leak,
check all the hoses on your engine, and listen for hissing while it runs, vacuum leaks are often found by hearing a hissing, even when the brake booster leaks and you hear it hissing by your feet while you drive,,
Good luck, if you find anything and have more questions, leave me a comment, I'll help you!
Mar 24, 2015 | 2003 Saturn ION
Have a phiips tv had it in storage for over a year turned it on an the screen working perfectly but there a hising noise coming from the back of it do no what it is... Its a big bk tv not flat screen box...
hissing noise will be from high voltage regulator, i would suggest to do following:
1. switch tv off
2. remove plug from the wall
3. using air blower (compressor attachment - not leaf one!) blow the dust, especially from high voltage box section
4. connect the tv and switch on
if tv still issue hissing noise - follow 1 and 2 then:
3. remove back cover
4. use air blower again...
5. re-install back cover
6. reconnect tv and switch on
if hissing noise persist - check for blown capacitors on high voltage, replace if necessary, they have nasty tendency to pop if they are too long in storage, especially if tehy were overheated or frozen.
hope this will help you solve the problem, do not forget to vote...
Jan 27, 2015 | Televison & Video
I was given just the camera. How can I actually use it with skpe?
I use skype and the program is free for web cams. Just go to www.skype.com and download their free software for web cams. They want you to set up a user name so fill out the form they post in order to use the webcam on skype. The software should find your webcam automatically and you then can add your freinds that use skype by sending them a request. After that you can call them or they can call you. A window will pop up when you get a skype call and you can accept or reject it.
I hope this helps you out.
Apr 01, 2011 | Microsoft LifeCam VX-6000 (68C-00001)...
Occasional hissing noise from a/c 2000 gmc sierra
This is pretty normal, the way the system works is by forcing liquid freeon through a orifice, the liquid turns to gas and gets very cold, the hissing is that process. You might be a tad low on freeon, but you shouldnt be worried.
Apr 05, 2010 | 2000 GMC Sierra
Garmin Rino 530 radio noise even with squelch turned up. Hissing
Are you carrying a cell phone with you at the time? A cell phone can interfere with these units. You may want to call Garmin to ask questions on this problem. They are very helpful and professional.
Dec 30, 2009 | Garmin Rino 530 GPS Receiver
What would cause ice crystals to form on propane line
Bad hose, bad tank, or seals are gone. Recommenend buying a new tank and new hose. The Ice is from the propane freezing and the hissing noise is a leak from somewhere. Better to replace tank and hose and try again. You do not want to take a chance with propane
Apr 11, 2009 | Weber Genesis Silver B Grill
Hissing.
If the hissing noise is from the LCD, it could be from the power supply due to failing capacitors. This noise is generated when the TV is trying to compensate for the lack of voltage/curent requirements.
Nov 04, 2008 | RCA L32HD31 32 in. LCD HDTV
Total loss of sound...what to do?
please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Sep 23, 2007 | Marantz SR-5200 Receiver
Logitech QuickCam Webcam Logo
538 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
