Sony KV-20EXR20 TV
Hi Pravin,
Thanks for your help with the Projection TV.
This question is regarding my 20 inch regular (CRT) TV.
2 days ago I was watching it and it was fine. I turned it off to go give my housemate a ride, came back turned it but there was nothing. I can hear the Click when I turned it on but there was no Sound or Picture.
Is this a Power supply failure?
I opened the TV, the 2 fuses inside are OK. I followed the digram inside to go into Service mode but again no picture or sound, jusk the TV clicks when I plug it in and when I turn it off or on.
Can you help please.?
Thank you,
AJ.
techman
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
  • 275 Answers
SOURCE: sony kv-32s26 32 inch tv
Could also be faulty Power supply. If Proper 110 V is not generetaed by SMPS, the above symptoms appear.
Posted on Sep 18, 2006
  • 556 Answers
SOURCE: Sony KV-29-SN21 TV power supply clicks, no picture no sound
DO NOT PUT ON TV As it is DANGEROUS call tv tech to check high output in regulated power supply
Posted on Sep 16, 2007
SOURCE: black screen no sound
Look at this
Phillips/Maganavox TS3258 Dead, HOT shorted R&R Flyback, HOT
Transistor,#3610- 22k, #6328 SMD diode, #7325 SMD Transistor and Check
#3611/3608 190 ohm resistor by #3610
TELEVISION MAGNAVOX TS3258 Flyback Bad Replace fly -
R3610,22K-R3331,47K(SMD)-D6328(SMD)-Q7325(SMD)-IC7150
TELEVISION MAGNAVOX TS3258C101 DEAD Shorted flyback, will also damage
IC7150, R3610, R3331, D6328, and Q7325.
Posted on Nov 13, 2007
  • 4102 Answers
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
35 inch Sony Trinitron TV 1999-KV-35V68. Video 1,1,3 displays on the screen, thus interrupting regular cable programming. We have used the Clicker for this Sony, repeatedly to change back to the progam and...
Press Display button on Sony tv remote, on-screen display will disappear.
If that does not solve the issue then tv gets problem in charcter generating circuit (part of system control chip) and visual check by professional is required to get it repaired.
Thanks.
Feb 16, 2011 | Sony Televison & Video
Sony KV-32FS12 32" TV what is the weight on this TV set?
It weighs 165 pounds. Also, Width: 31.5 inches. Height: 27.88 inches. Depth: 23 inches.
Nov 28, 2009 | Sony KV-32FS12 32" TV
Sony 51 inch Projection TV.
Dear AJ,
To be very Honest, i am not well conversant with Rear Projection TVs.
I suggest that you try with someone else.
Again from my personal point of view, i am of the feeling that itcan be fixed, and pretty easily. There must be a "Service Mode" which can be accessed by the remove, and then the Convergence Settings / Adjustments can be corrected.
But, I shall make additional enquiries and and let you know.
Cheers
Pravin
Dec 01, 2008 | Televison & Video
Sony wega 32 inch
Hi if light blinks on any sony tv it the fallowing
1 screen adjustment in expensive repair you need a tv center
2 power supply problem fix is 85.00 to 120.00
3 flybak problem high voltage est 225.00
this will at least help you so you will not be taken advantage of when you call a service center
thanks DOCTOR VIDEO LEADINGEDGEREPAIRCENTER SINCE1987
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Auxilary problems
press the ANT button on sony remote. otherwise take to tv repair man
Mar 22, 2008 | Sony KV-27V42 27" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
KV-32XBR250 Has about twenty Horizontal, Light Red bars aternating
your problem is called retrace lines it is due to 1 supply to red out put is absent 2 problem in red video output 3 loose contact in red output ckt 4 connector loose 5 crt base loose 6 circuit from red output of chroma ic to red video input 7 chroma ic defective regards
Sep 11, 2007 | Sony KV-32XBR250 TV
No Power on
Hello, please check the transistor 2SD1878 near flyback transformer and fuse PS801. Best regards, Arpi
Jul 18, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony36xbr400hdtv
Hi there, please change the Flyback transformer. Best regards, Arpi
Jun 16, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
