Question about Sony VAIO Digital Studio PCV-RX560 PC Desktop
Hardware monitor error
My pc cant open to the win xp and it said hardware monitor error
  • 69 Answers
Sounds like loose connection on your monitor card, if installed seperately, otherwise the wrong drivers installed.
Boot up in safe mode and uninstall the monitor drivers. and try and boot again.
Let me know if need further help.
regards,
Philip
Posted on Dec 01, 2008
  • Kuldip Singh Dec 01, 2008
    regards,
    Philip
My monitor hp 1702 is saying monitor is going to sleep. I cant even get my cd part to open windows xp professional 1-2 cpu hp
It sounds like you have the problem with the PC itself, you can try this monitor with another PC just to narrow down the problem.
The PC mayhave hardware problem usch as bad power supply that may explain why you cannot even open the CD tray.
Jul 12, 2011 | HP L1702 17" LCD Monitor
Tip
Hi! Plz help me I have satellite L305-S5908 I had deleted my windows vista 64...
NOTE: This Tip can be Hard, I recommend Advanced Users Only.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we'll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don't just use the default. I chose roughly 10gb by entering 10000 into the amount.
This step might be confusing, because we need to change the cd-rom drive that's invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it's already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn't the end of the world, but it's not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we'll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it's easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you'd like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can't do the next step until we reboot. (you can try, but it won't work)
So we've come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like "XP". It would be wise to name the C: drive to "Vista" at this point as well.
Now you'll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like "Hit Esc for boot menu" you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don't try and install onto your Vista partition! See how much cleaner it is now that we've labeled each partition distinctly?
We'll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we'll need to use the VistaBootPro utility to restore the Vista boot loader.
Download and install VistaBootPro from vistabootpro.org
During the install you'll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the "Windows Vista Bootloader" and then "All Drives" radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you'll only be able to boot into Vista, but we'll fix that. Instead of manually doing the work, we'll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the "Manage OS Entries" tab and then click in the textbox for Rename OS Entry, and name it something useful like "Windows XP" or "The Windows That Works"
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying "unable to find ntldr" when trying to boot XP, you'll need to do the following:
  • Find the hidden files ntldr and ntdetect.com in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can't find the files there, you can find them in the \i386\ folder on your XP install cd
You can share information between the drives, but I wouldn't recommend messing with the other operating system's partition too much… it might screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition "Data".
This works if you have the operation system "Windows Vista."
on Mar 28, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My computer reaches the win xp starup screen then a blue screen flashes theen it restarts
There are a lot of reason why this is happening. It may be a newly installed hardware, one of the hardware is damaged or it may also be the RAM. You can try reseating the ram first. If that does not help, if you have hardware connected through USB, disconnect it first.
Install the operating system (win XP) with the mouse, keyboard and the monitor connected. Other peripherals (hardware) should be disconnected to the tower.
Apr 20, 2011 | Microsoft Windows XP Professional SP2
Ihave win vista in my pc please i want to setup win xp but
some systems can not be reverted back to windows xp because of drivers not being available. i have tried this before. u have to talk to manufacturer and ask can you do it.
Dec 12, 2009 | Racer AcerPower F5 PC Desktop
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
I reloaded win xp get lowest res. cant get higher res
sounds like you need a driver for you video card go to driver.com
Dec 14, 2008 | HP W1707 LCD Monitor
LG Flatron L1750H
Hi there, my name is Alex and I am here to help solve your problem.
When adding a new monitor to your computer, it is not necessary to install the monitors drivers as it should detect 'Plug and Play monitor' and will install the monitors drivers automatically. Are you getting any error messages?
If you have any questions or needing further assistance, then please contact me.
Oct 10, 2008 | LG Flatron L1750H (Silver) 17" LCD Monitor
Out of frequency LG500g
15"LG Studioworks500g Monitor Supports Up to 1024by768pixel resiolution.
First U can check UR system res is High and than Go to Enable VGA mode on ur system.
Sep 20, 2008 | Computers & Internet
Sony VAIO Digital Studio PCV-RX560 PC Desktop Logo
146 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
