Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage dr won't close because trolley interferes with rail joint
The door can't open because the interference causes the door to go back up. There is a loud bang when this occurs. I disconnected the door from the tolley and tried to fiddle with it and it seemed to fix the interference, for one closing. Then it went right back to interfering.
Anyone else experience this problem?
It's a Sears Craftsman opener, around nine years old.
  • 504 Answers
Run the unit with the door unhooked.
Work the door manually.
If the door works smoothly and easily up and down and the opener works normally when not connected to the door you probably have a bad gear kit.
Unplug the unit - take of the cover – if you find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
HOPE THIS HELPS
Posted on May 29, 2010
Garage door opener remotes work OK on OPEN but have short range on CLOSE.
try adding on the antennaes, ive had success with this in the past
Nov 15, 2014 | Building Materials
I have a Clicker universal Garage door opener remote control Model KLIK1U. How can I increase the range to open the door? Currently, I have to be within 10-15 feet of the door opener to operate. I have...
Check the antenna on the motor. It is usually a single thin wire. There also could be something nearby that is causing interference to the unit and it wont pick up the signal till the transmitter is close enough to overpower the interference.
Oct 28, 2013 | Building Materials
Craftsman 139.53985 worked fine for 2 1/2 yrs, but now only will open/close with the remotes at close range and not at all when on other side of closed door (inside wired control still works). Whats wrong?
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Oct 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
1/2 horse garage door opener doesn,t open all the way. I need about a foot more lift. The tried a trolley stops before the stop limit..Therre is no interference. I Tried adjusting the up limit to no...
You said you adjusted the up limit already. Is it adjusted as far as possible? Usually the screw will become harder to turn. You mention a new door and spring but is the opener the same? My guess is you have a new opener as well and it is out of sync with the trolley. Try turning the up limit back and see if the trolley will stop shorter. If it does, loosen the chain or belt so that you can remove if from the opener's drive gear. Bring the trolley to your stop limit and put the chain/belt back on the gear. Adjust the chain/gear tension and try door operation again. If it was a sync problem, the door should close closer to your limit. Adjust up and down travel as necessary to fine tune it. This worked for me so good luck.
Sep 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Track rail bends when closing the door
I think you need to take the cover off the motor unit and watch the limit switch assembly in operation. Takes only a few seconds to see how it works and see if it is damaged in some way. You need to turn the down limit adjustment in the opposite direction of the arrow printed on the cover to stop the door sooner. I think the down force adjustment on the rear of the motor unit is out of adjustment also. This adjustment affects the safety of the opener and should only be adjusted high enough to consistently close the door.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote control signal problem
On the rear of the motor unit just to the left of all those white wires you will find a small LED. Random flashing is normal but if it is flashing rapidly it shows some type of interference. If this isn't happening then the most common thing is a logic board going bad.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't go down because of interference
IF YOU ARE TALKING ABOUT THE JOINTS IN THE RAIL THE TROLLEY TRAVELS ON THEY USSUALLY ONLY GET OUT OF ALIGNMENT WHEN THE BOLTS THAT HOLD THE SECTIONS TOGETHER ARE LOOSE.
Dec 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
52 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
