Computers & Internet Logo
Posted on Jun 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Annoying noise high pitched continuous noise
Anonymous
Level 3:
  • ASUS Master 6,771 Answers
  • Posted on Jun 13, 2012
Anonymous
ASUS Master
Level 3:
Answers
6771
Questions
0
Helped
1779358
Points
21413
The noise is probably coming from the hard drive, remove it and see if that will solve the problem. That high pitched sound means the hardware is on it's way out.
High-pitched noise from Honeywell Humidifier
Sounds like the high pitched noise is coming from the solenoid valve which allows water to enter the humidifier. Typically when the water pressure is too high, it causes this high pitched sound at the solenoid valve. You can adjust the water pressure a little at a time and see if it helps, just make sure you’re getting enough water across the water panel.
1985 toyota mr2 engine noise
It still could be the throw-out bearing. When going bad, they have a high pitched whine or whistling, and if bad enough, could imitate a vibrating sensation. IDK, I would have a mechanic there listen to it.
1helpful
2answers
Fridge making annoying high pitch noise almost constantly
mine had a recall on the chipboard. fixed the high pitched buzz, but now i can hear the motor running stronger.
Whining noise from freezer
Fan motor is bad and needs to be replaced.
2helpful
3answers
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
High pitch noise when tv warms up
High pitch noise is created mostly by a Coil or a transformer,is not easy finding the source if you are not familiar with this type of coil since there many sizes and shapes,the set needs to be on while trying to find wich part is doing it SO if you dont know where and how better call a Technician and you will be safe.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
