Question about Dirt Devil Vacuums
Where do i put the water and the solution????
  • David Cleary May 11, 2010
    What is your make and model?
  • 125 Answers
Instruction manual is on
Posted on Dec 01, 2008
The dirty water tank will not fill up
Make sure it's putting the right amount of water down. Many machines brought in to my store for repairs are putting down just a small amount but people think its not extracting any when the real problem is not putting out enough water.
If that's not the case make sure there are no clogs or suction leaks anywhere which will greatly reduce water extraction.
Mar 15, 2017 | Vacuums
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
I don't have instructions for the Rainbow shampooer. I'm not sure how much water to put in, or whether I put water in both reservoirs. Does anyone know?
Water only goes into the cub in the handle. The dirty water gets put into the bowl on the canister part.
Nov 28, 2009 | Rainbow Vacuums
Don't know how much water to use in Scunci Steam Cleaner
The little cup that comes with it to fill it has a line on it and says "220ml MAX". I would not recommend putting anything but water into it!
Aug 08, 2009 | Scunci 52067 Handheld Steam Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Do you put hot water in the tank
It would depend on whether you machine preheats the water or not,and what kind of machine,Bissell,GE,etc..If your machine doesn't heat the water,then I would use hot water.Do not boil water,tap is fine.
Dec 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
There are two tanks on that machine. The lower tank is the recovery for the dirty water and the upper tank is for the clean water solution. You mix the detergent with the clean water and away you go.
Feb 08, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Lost directions to the cleaner.
Hi , check the water level and refill it .
Jan 21, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
