Question about Panasonic PT-51G44 51" Rear Projection Television
Low contrast, adjusting contrast control has no affect. the bar does move back and forth. replaced caps around video procesor ic, also replaced an5165k ic.appreciate any suggestions thanks clinton.
    Sergeant:
  • 308 Answers
You'll probably need a service manual for this one. You will have to check to see if the microprocessor is changing the voltage levels to the video IC as the problem could be with the CPU as long as the screen voltages are not out of whack at the CRT's or that they are bad.
Posted on Jan 28, 2007
My new AOC 27"LED has a vertical white line moving back and forth on the screen. as it moves left, contrast is reduced and as it moves right, contrast is restored
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 08, 2017 | AOC Televison & Video
Measuring spoon wheel adjuster
you need to have it properly aligned, the tracking is different on every vehicle there is an amount of play in the adjustments but if it will not go into the recommend rang on the alignment then there is a problem, before taking to have this done make sure the tracking nuts and bars are easily moveable, undo them and move back and forth as if they find it hard to move they charge you more, if they can undo the nuts and move the bars around easy they cannot charge you for the extra charge. also make sure you have new tyres fitted as work or uneven ware can affect the camber to the road and wear the tyres down quicker and cause other problems later on.
Jun 21, 2017 | 1998 Ford Windstar
Univerum tv control memory ic
You have to initiliaze the TV, after memory IC replacement. For more details, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | Televison & Video
How do I take chain off and tighten and then put back on.
The chain is not removed to tighten it.
Somewhere around where the bar (the "plate" the chain runs on) is attached to the body of the saw, there is a knob or screw which moves the bar back and forth.
Moving the bar back and forth control the tension on the chain.
Moving the bar away from the saw body tightens the chain, moving it in loosens it.
Charlie
Aug 28, 2009 | Ryobi Garden
Contrast setting is too low, and the button is broken. Help!
Adjust the contrast permanently in full, if the control button in the front is broken you must adjust it inside. The brilliance has to controls in front and at the back inside ( the lower one) (the upper one is sharpness control) you can make there your desired adjustment.
Apr 27, 2009 | Computers & Internet
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
LG 700E MONITER britghtness and flicker
trace abl from fbt to video preamp ic.
replace ic if nothing found bad.
Sep 23, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor goes black
Hi...there, It's could be 2 things...either your cables inside is lose or one of your caps is leaking fluid from the inverter. Turn off the power and open the back casing to check all the cables are secured. Good luck!
Aug 07, 2008 | Westinghouse L1975NW Monitor
Casio g-shock 2900
Hi there
There is no contrast adjustment...
Batteries low can affect the contrast. Try replacing the batt first. Is it all black? If so, the LCD is damaged.
Feb 14, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Panasonic PT-51G44 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
