Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
No Spin Cycle
My washer will go through the every part of the cycle and then it gets mid way throught the rinse cycle and it just shuts off like its done. No noise, no spin, and it doesn't drain out. I tried checking the lid and everything was fine there. I even restarted the cycle and it did the same thing. So now I a washer full of water and wet clothes.. Is this a simple fix or do I need replace my washer?
  • 240 Answers
If its not a lid switch then I'd try a timer. if your lid sw has a hole on the right side for a pin - those are particularly troublesome. housing tends to separate. new ones are hidden.
Posted on Dec 01, 2008
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
How can I fix the LED monitor so the cycles do not change mid cycle?
It sounds like a control problem. I assume it is electronic, and if so try another control board but be sure you can return it if it does not solve your problem.
Jan 11, 2015 | Haier Hlp23e Portable Top-load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
I need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you
Reply to rutledge5135 on Apr 11, 2011
(i need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you)...
The 'S' is for 'Spray' which happens at the beginning of the Spin Cycle...it then goes on to rinse etc.
regards, avery.phill@gmail.com
Apr 11, 2011 | Hoover Washing Machines
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
