Question about Canon ZR300 Mini DV Digital Camcorder
Canon zr 300 won't take tape inside
The camera won't take tapes down. Retracts and goes back down if tape is not present, but if I put any tape in it will make funny noise and eject tape without taking it in to the camera!
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Posted on Oct 23, 2010
  • 2 more comments
  • Scott Nichols Nov 16, 2010
    Tried this last night with my ZR300 that had the same issue with the tape not loading. Had to hitit twice but it now loads fine! I called Canon and they said the repair would be 150-400 dollars. I'm glad I looked here because the solution worked perfect!
  • Chech76 Jul 10, 2011
    I thought this was BS, but I had nothing to lose since the camera would not load the tape. I opened it up and allowed the tape mechanism to pop open. I then closed it it up, gave it a slap on the side, opened it back up, put a tape in, and it worked. One good whack is all it took. I did not hit it really hard, but it apparently knocked something back in place.
    Go FONZIE.
  • Godchick Aug 26, 2011
    Oh wow! We just tried it with our Canon zr 300 and by gum it worked! My husband closed the camcorder door with obviously no tape inside then gave it a good whack, kind of a spank, on the top of the loading door and he then opened it and it was able to take a tape again. Strange but true!
  • David Prince
    David Prince Apr 01, 2014
    That worked!!!!!
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
My canon dvc keeps telling me to reject my tape. It retracts just fine. But it won't let me record or play back. please help!!
I have the same problem. The only solution I've found is to manually wind the tape forward about 15 seconds and it works fine again. The problem only occurs if I let the tape wind all the way to the beginning.
Aug 03, 2010 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Canon ZR 600 tape won't load
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
Dec 31, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Canon zr video camera
Get to Canon and see if they will spring for a new carriage assembly, as this is usually the culprit...accordianman
May 20, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Feb 11, 2008 | Canon ZR300 Mini DV Digital Camcorder
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
happened to me too.. only with a sharp vl z3. It happened to me because it was filming while the battery ran out so the film is still in the camera!!! noooo!!! dang it!
Nov 20, 2007 | Video Cameras
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Canon ZR300 Mini DV Digital Camcorder Logo
430 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
