Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door won't go down because of interference
The trolley? (the part that is connected to the chain and slides over the rail) that pushes the door down seems to be jolted at a connection joint of the rail. At first it made a banging sound but closed. Now it hits at the same spot and the door goes back up. I disconnected the door to fiddle with the trolley and it worked one time. Then it started banging again.
Can the trolley be replaced?
Any help would be appreciated.
  • 504 Answers
IF YOU ARE TALKING ABOUT THE JOINTS IN THE RAIL THE TROLLEY TRAVELS ON THEY USSUALLY ONLY GET OUT OF ALIGNMENT WHEN THE BOLTS THAT HOLD THE SECTIONS TOGETHER ARE LOOSE.
Posted on May 28, 2010
1/2 horse garage door opener doesn,t open all the way. I need about a foot more lift. The tried a trolley stops before the stop limit..Therre is no interference. I Tried adjusting the up limit to no...
You said you adjusted the up limit already. Is it adjusted as far as possible? Usually the screw will become harder to turn. You mention a new door and spring but is the opener the same? My guess is you have a new opener as well and it is out of sync with the trolley. Try turning the up limit back and see if the trolley will stop shorter. If it does, loosen the chain or belt so that you can remove if from the opener's drive gear. Bring the trolley to your stop limit and put the chain/belt back on the gear. Adjust the chain/gear tension and try door operation again. If it was a sync problem, the door should close closer to your limit. Adjust up and down travel as necessary to fine tune it. This worked for me so good luck.
Sep 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
On my craftsman 1/2 hp garage door opener connected to our 20 year old garage door, lately it has been getting stuck only about a foot off the ground, the chain is saggin so that when the garage is open...
It may not be the opener causing the problem.Unhook the opener from the door by pulling on the red disconnect handle. Push the door down or pul;l it up by hand by pushing or pulling on the top center of the door where the opener link hooks to door.See if it moves freely or sticks at the place you described.You could have a door spring problem if the door works ok manually the gear/sprocket in the opener is worn.This is an expensive repair and it might be cheaper to replace the opener.The loose chain could be a sign that the sprocket bearing is worn also.If it is not worn the chain is adjustable at the trolley assembly that slides on the rail.
Jul 31, 2009 | American Gardener Rh30 22" Readyhedger 3.0...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens 1 foot, then stops.
It sure sounds like you have a broken door spring. While you are at it remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Might be stripped and unable to take the weight of the door.
Jun 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
How is the chain supposed to be aligned
sync the motor. the gear kit tells you how. get motor up and position trolley near motor, assuming you left chain/cable attached to trolley). Get motor up by running motor and then pushing button again. if motor reverse, let it run and it will stop in up position.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Installed new worm gear, but now i cant get the door down
Check to see if the 4 wire harness is hooked up from the limit assy.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage dr won't close because trolley interferes with rail joint
Run the unit with the door unhooked.
Work the door manually.
If the door works smoothly and easily up and down and the opener works normally when not connected to the door you probably have a bad gear kit.
Unplug the unit - take of the cover – if you find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
HOPE THIS HELPS
Dec 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
155 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
