Question about Kenmore 63942 Dryer
Kenmore dryer won't start?
My dryer won't start,the lights all light up and than the lint light comes on and i slam the door shut and than no noise but all the lights go on, can you help me? sheri
  • 63 Answers
Thermal fuse
Posted on Jan 20, 2009
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Jan 02, 2012 | Kenmore Dryers
Dryer not starting
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
Feb 27, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have a kenmore gas dryer 110.74832400 doesnt heat
You stated you checked all lints roblems. Just to make sure. Did you remove the lint catcher completely on the inside? If not take that off and clead the lint out of the inside of the duct. Also lint can build up inside the lint duct on the rear of the drier and in the duct going outside of your home.
Jun 03, 2009 | Kenmore 75962 Gas Dryer
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Dryer problem
Dryer didn't work after a flash of light & light burning out. I slammed the door shut and now it works ever since.
Oct 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
233 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
