Question about Creative Labs Nomad MuVo TX MP3 Player
Says there's no music
If i plug it in to the computer it says there's music but it will freeze if you try to play it on the computer and when i try to use the mp3 player it says there's no music on it, whats wrong?
  • 3130 Answers
SOURCE: Audio Problems With MP3
First thing you wanna do is to try another set of headphones. If it still sounds muffled then theres a fault in the audio output section and these things are non user serviceable. Your gonna need to send back to the manufacturer. Good Luck
Posted on Apr 27, 2006
  • 45 Answers
SOURCE: won't format and won't play mp3
try loading files on different bit rates and see what bitrate your player can play. some player wont play files that are directly copied to the player, it needs a certain software to encode it to its standard format. sony walkman is an example, it has its own software to encode files from mp3 to its own supported format.
Posted on May 17, 2007
SOURCE: computer wont recognize mp3 player
Hmmm when you plug it in to put music on it do you use the sync manager thing? thats what i use and sometimes it says theres no player connected even though there is, so i just keep plugging and unplugging until it works.. but then if that doesnt work i just go to  "Zen v series media explorer" it like lets you upload music there too.. hope you find something that works!
Posted on Oct 14, 2007
  • 555 Answers
SOURCE: muvo v100
My MuVo was having problems until I installed the latest firmware. The last firmware release was in July 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo V100 Firmware 1.05.01.
If you can't get your computer to even recognize the player anymore, you could try reinstalling the Creative Mass Storage Driver
Posted on Feb 26, 2008
  • 12 Answers
SOURCE: creative zen v problems-frozen
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
Posted on Mar 25, 2008
  • 4 Answers
SOURCE: frozen
Try to download the "fixer" from Creatives homepage.
Posted on Jun 15, 2008
0 characters
1 Points
Itunes wot connect to ipod also ipod plays music but when i try to skip songs it freezes for about 10 sec then it plays again.
Try connecting to another computer's iTunes. If the computer recongnizes it, it could mean that your computer's USB ports are malfunctioning.
Jun 25, 2010 | Apple iPod classic MP3 Player
SlicK mp4 2GB freezes when I plug it into my computer
Try reset, I reset doesn't work go to the computer and delete the extra text files.
Mar 21, 2010 | Bell Technology Techsolo Slick Stick MP3...
SanDisk freezes when trying to play a song, then it restarts itself.
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works.........Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier.....
Then disconnect from your computer and see if it worked
Hope it does..........Please rate
May 17, 2009 | SanDisk Sansa e260 MP3 Player
My iriver e100 keeps freezing. I tried making a playlist and as soon as I select a song to listen to out of the playlist, the screen freezes and no music plays...
Hey guys,
I had a similiar problem. Apparently when you download music from limewire etc. and upload the music to your iriver, you can upload viruses also. Limewire is very dodgy for this. I'd say delete those songs that are freezing from your player and computer, they may be infected and causing the freeze.
May 18, 2008 | MP3 & Digital Media Players
It freezes
Have you tried removing the battery when it freezes? Sorry I can't be more help
Apr 29, 2008 | SanDisk Sansa e250 MP3 Player
2 gig go gear frozen and caused computer problem
call philips and have them walk you through a repair and update
Mar 26, 2008 | Philips GoGear HDD1830 MP3 Player
Wont play music
Try solution 4 here:
It works for any e200 series. The firmware is the same just the memory chip is different.
Feb 26, 2008 | SanDisk Sansa e260 MP3 Player
Mp3 player freezing up when i try 2 play music player is stuck and I tried reseting doesn't fix the problem
Try reformatting the player by plugging it in your computer and when it's drive letter appears, right-click then format. It will erase all music files so you need to put the music back again and see if the problem persist. If it still persists, it might be the music source when copying. Try using direct drag and drop instead of syncing in music from a media player.
Feb 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Creative Labs Nomad MuVo TX MP3 Player Logo
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
