Question about Ovens
My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
The top microwave part of the unit has a melting chamber, the plastic top part of the microwave appears with a melting bubbly appearance, and part of the microwave ceiling is also exposing metal! Since the oven on the bottom unit is still working fine, I'd like to replace just the microwave, is that possible? The model is #JKP85B0A3BB
  • 78 Answers
It is one unit. You can not replace just a microwave.
Posted on Dec 01, 2008
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Kitchenaid selectra
possible but unlikely. they are physically connected?
Mar 07, 2014 | Ovens
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
My daughter did something to the door... when you close the door and set the time and start the display reads 'DOOR' as if it isn't closed and it won't start. Thanks for any assistance. Whirlpool...
i have seen this a few times. the m/w portion has seperate fuses and sometimes the cartridge fuse can be blown. it is located inside the top above oven. hard to get to without pulling the unit and getting the top off of unit.
others have had a failure in the microwave control board.
Jan 10, 2010 | Whirlpool GSC308PRS Stainless Steel...
GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Oct 25, 2008 | GE JKP85 Electric Double Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
is this model mounted over the oven as one piece unit?or does it hang above the stove?
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven/combo unit
http://www.repairclinic.com/SmartSearch/smartsearch.aspx go here enter your model number then under parts select all parts not listed and its on page two
Feb 08, 2008 | Ovens
Ovens Logo
273 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
