Question about Whirlpool Dryers
Dryer no heat
I turn on the dryer run no heat
  • johntang Dec 01, 2008
    How do i know heat sensor it bad ,what about Element heat ,It do go out some time. Thank.
  • 55 Answers
It might be the heat sensor.take the panel off the back and you will see the heating element and up above that theres a sensor that has two wires to them.if thats bad you can replace it or you can just hook the two wires together and bypass it and it will cost you nothing.
Posted on Dec 01, 2008
  • Daniel Grimm Dec 02, 2008
    u can unhook it take a volt meter put it on continuity and if it dont then its bad.same with the heating element.but i would be suprised if the element went out before the sensor.the sensor is usually the one to go first.you can also like i said just disconnect the two wires one the sensor and put them together and turn it on if your heating element heats up than your good.you do not need that sensor in order for your dryer to work.all that sensor does is complete the circuit so when it goes out the circuit is no longer complete,and all you have to do is twist those two wires together with a wire nut and you have a complete circuit.
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Load clothes in dryer from the washer. Heat seems to be fine however drum stops turning after a period of time and heat inside dryer very hot but still sounds like a motor is running.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 08, 2010 | Maytag SDE3606A Electric Dryer
Gas dryer initially heats then heating stops
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
My Roper dryer quit running...it's heating but doesn't seem to come on or tumble.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
REX4634KQ Electric Dryer: dryer heats up but won't turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
May 18, 2010 | Roper REX4634KQ Electric Dryer
Dry run no heat
Dryer Repair - The
Dryer Repair - The
heatman101
May 15, 2010 | Roper REX4634KQ Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryer runs and heats but drum won't turn.
you need to replace the belt on your dryer
Dec 26, 2008 | Whirlpool LGR8648 Gas Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
