Clutchless motor relay chatters GE Profile Prodigy WPSE4200A
The motor was replaced to a clutchless motor about 1 year ago. Recently the relay contacts burnt up and the motor won't start. New relay was installed and I can see the motor try to start but the contacts still chatter and I see them arcing. The capacitor was discharge for testing and with a digital meter I see numbers pop up momentarily on the k olms scale and then 0.L each time the leads are reversed. I even tried a new motor.
  • 1,543 Answers
Can't really test a capacitor with digital meter (analog with a 10K scale works much better for that) but your problem is most likely the wire lead(s) to the capacitor. Check the two yellow wires, especially at the push on wire terminals which go onto the capacitor.
Posted on Dec 01, 2008
Testimonial: "Yes the wire was broken because the insulation crimp was poor"
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy will not drain water out. It starts and then stops after about a quarter of the water is drained out
Check your hoses to water pump,appears to be a restriction. Have a shallow pan and towels to collect water
Oct 24, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Lights but no action
Sounds like a faulty control board. This board controls ALL functions of this machine. This can be a major expense for the age of the machine.
Nov 09, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
