Question about HP PSC 1315 All-In-One InkJet Printer
My printer sounds like its printing but the pages are blank and I can't launch my HP Director to check the ink levels, (which I don't think is my problem but wanted to check it anyway.) Can you help? Thanks Rose
    Scholar:
  • 81 Answers
If you have the install disk have it with you.
go to your control panel and then printers and faxes and delete the printer. Then unplug the usb cable and replug it in. It will ask at some point for the disk (probably but may not) and make sure to select it as your default. Once done try and print again from more then one application. Make sure the printer menu lists the HP and see if any issue occurs. The driver might have gotten corrupted and just needs to be reinstalled.
Posted on Dec 01, 2008
How to check ink levels in a HP officejet J4580 printer
Checking ink levels
  1. open HP solution center on the computer desktop screen
  2. click on settings on the bottom
  3. click printer toolbox
  4. click the estimated ink levels tab
or
  1. on the printer control panel,push the wrench button
  2. press the right arrow to go to print report
  3. push OK
  4. select self test
  5. push OK
It will print a page with color bars signifying correct ink levels.If a color bar is blank it means it's empty or depleted and needs to be replaced
Jul 21, 2011 | HP OfficeJet J4580 All-In-One Laser...
I want to check ink levels. It is blurring the color when printing
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Jun 21, 2011 | HP LaserJet CP1518 Printer
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
Oct 05, 2010 | Office Equipment & Supplies
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
to check the ink levels go to hp director in your computer START>ALL PROGRAMS> HP or HP DIRECTOR. Click on PRINTER SETTINGS>TOOLBOX. and then view the estimated ink level of the print cartridges
Aug 31, 2009 | HP PSC 2175 All-In-One InkJet Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
The printer acts like it is printing, but doesnt actually print
uninstall ur printers driver and re-install it. This will deffinetly solve your problem but then also giving u a word of caution repair your windows Operating system. Its easy just put ur cd and do whatever it asks until repair comes and put it on repair option. your spool.exe is corrupt by virus
Jun 16, 2009 | HP DeskJet F380 All-In-One Printer
Acts like its printing but no ink on paper
Using HP Director, you should be able to check estimated ink levels by selecting Settings -> Print Settings -> Printer Toolbox and then clicking on the Estimated Ink Levels tab.
If the ink levels appear to be sufficient, on the printer control panel press Setup, 1, 4. This will generate a self-test report. If there is streaking of any of the 4 bars at the bottom of the page, the affected cartridge may need to be cleaned. If any of the bars are missing, the cartridge needs to be replaced.
To clean the cartridges, press Setup, 5, 1. This will print a page of patterns.
Mar 17, 2009 | HP Officejet 5510 All-In-One Thermal...
Neither black or color will print..
remove and check cartidges it is quite possible that the cartridges must hve dried up.
Dec 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
70 people viewed this question
Seeker5211
Seeker5211
